Bragg cell in laser doppler vibrometer
The Bragg cell in a laser Doppler vibrometer (LDV) is crucial for determining the velocity direction of an object by modulating the frequency of the laser beam. When the object moves towards the interferometer, the Bragg cell shifts the frequency of the laser beam, reducing the modulation frequency. This frequency shift is influenced by the Doppler effect, where the diffracted beam's frequency is altered by the sound wave's frequency. The output frequency from the Bragg cell is not fixed; it can fluctuate based on the object's movement and the acoustic waves used. Understanding these frequency changes is essential for accurately measuring the object's velocity direction.
zaimir83
I know that Bragg cell used in laser doppler vibrometer (LDV) is used to give information about the direction of the velocity of the object that we measure. I also know that Bragg cell will shift the frequency of the laser beam(modulation frequency is reduced) when the object is moving towards the interferometer. But the problem is I want to know how Bragg cell can reduced the modulated frequency and next increased the frequency so that we know the velocity direction of the object. Can anybody explain?
I think the vibration frequency your are trying to measure is what is used to do the modulation?
One difference from Bragg diffraction is that the light is scattering from moving planes. A consequence of this is the frequency of the diffracted beam f in order m will be Doppler-shifted by an amount equal to the frequency of the sound wave F.
http://en.wikipedia.org/wiki/Acousto-optic_modulator"
Welcome to PF zaimir83
Thank you dlgoff.
I still could not comprehend the statement well. For example, if I have a laser beam entering the bragg cell at 40MHz and the beam coming out of the cell have a frequency of 50MHz. Is the frequency coming out of the cell always has a fixed value? Or it will shift up and down over time?
In some AOMs, two acoustic waves travel in opposite directions in the material, creating a standing wave.
If you have this situation, then you would be able to see in which direction you accelerate the device. You would get frequencies shifted up in one direction, and frequencies shifited down in the other direction. I think.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
