- #36
Matter
- 13
would a spiral work!?
Missed a spot, there. You did not cross the segment directly to the left of the center of the figure.koroljov said:I found it. First try worked. (See attachment).
That's a good one! I bet the same thing happened with all those famous conjectures which were supposedly proven by mathematicians in the past, but whose proofs were lost. Fermat comes to mind...CrankFan said:I've heard of a similar problem to this one, which had no solution and was supposedly given to grade school students for extra credit. As if that isn't enough of a coincidence just like this version of the story it was rumored to have been solved by one student, so you "know" a solution has to exist!
I suspect that stories of this kind are intentional hoaxes which persist as a kind of elementary math folklore.
There are 5 rectangels with 4 walls each! 6 of these walls are shared or common walls . I went through each wall of each rectangel once ! so where did I miss one!Galileo said:Dude, you missed a spot.
It can't be done!
don't answer that I see it! Dang! I hate not having a solution!#"!Matter said:There are 5 rectangels with 4 walls each! 6 of these walls are shared or common walls . I went through each wall of each rectangel once ! so where did I miss one!
If going through a corner counts as going through all three then yes this is a solution. If that is not allowed then there is no solution as has been shown like 10 times throughout this thread. It depends on what conditions you put on the problem. So you decide: is that a solution?kerryfan said:I was given this problem as a brain teaser and am wondering if I've found the solution (see attachment) or if there is a solution besides cheating, use a marker, etc. This has been driving me nuts, please help if you know the answer.
Thanks
animejunkie1100 said:I have worked on it for like a year almost and still can't find the answer please help!
Brainteasercool said:the rules
you can go over a line one time
you can't go along a line
you can start in the middle or outside
you can have a straight line or a curved line
you can't cut or go through corners
bagelboy92 said:this seems to be impossible because first of all there is an even number of lines to cross for one line to go through and second of all i have made a NOTEBOOK of individual papers that have front and back non repetitive attempts...i lie to you not this is impossible...i have lost time trying to figure this out on a state high school test that determines if i pass high school! (Breathing hard like a maniac while saying that) ... ... yes I am okay but i tell you with confidence for all who read this that it is impossible
light_bulb said:i think this one is right?
