Breakdown Voltage Depends on Field Uniformity?
In summary, the question is asking whether the breakdown voltage is higher in a uniform electric field or a non-uniform one. However, the concept of breakdown voltage is not affected by the shape of the field, but rather the strength of the field at a specific point. Models of breakdown often assume a uniform field, but in reality, the field can vary and lead to more complicated phenomena such as Lichtenberg figures. To accurately model this variability, FEA simulations must account for small variations in the material. This can be challenging due to the random and chaotic nature of breakdown phenomena, which is why empirical data like Paschen Law is often used instead of a simple algebraic formula.
Ana Mido
Which is higher, the breakdown voltage if the electric field is uniform or the breakdown voltage if the electric field is non-uniform ?
The question is a bit confusing. As I understand it, the breakdown voltage is a specific threshold value not related to what the field looks like. Of course a "real" field may be pretty close to uniform in a certain region of space, but may very well be non-uniform in some other region of space. As you increase the field everywhere, breakdown will occur where the field happens to be the strongest because that's where the threshold value will be reached first.
The simplest models of breakdown do assume uniform field but that's not necessarily what any reality actually is. Models are approximations for us stupid humans, not because reality must follow the model exactly.
This is where/why you can apply these ideals to a FEA simulation - within each mesh element, the assumption is exactly that kind of uniformity.
You can get some complicated results in reality and in an FEA simulation because there may be some parts (if physical aspects are well modeled) that will cause a small piece to breakdown and then cascade to more complicated breakdown phenomena like the fractal curves of a Litchtenberg figure. The problem is usually you don't know, and have no way to find out, the specific, small variations in the material that create weak spots for that lead to such things. There's also random processes involve that assure it might not happen the same way twice.
This requires FEA that can model that kind of variability per mesh element in the "proper way" (e.g. defects per cm^3 or similar). It gets complicated for physical phenomena where the act of something happening (e.g. conduction from point A to point B) itself changes the probability of some other subsequent things happening (e.g. conduction from point B to point C, B to D, B to E, B to F... B to ZZZZZ). This s the nature of fractal and chaotic behaviors - deterministic models and behaviors becomes the wrong question. Breakdown phenomena have this kind of effect which is why there is no simple algebraic formula for the relationship of breakdown current vs. applied voltage. Instead you have to rely on empirical data like Paschen Law which are still only approximate.
https://en.wikipedia.org/wiki/Lichtenberg_figure
https://en.wikipedia.org/wiki/Lightning_strike
https://en.wikipedia.org/wiki/Paschen's_law
Likes anorlunda
Likes anorlunda
Related to Breakdown Voltage Depends on Field Uniformity?
1. What is breakdown voltage and why is it important?
Breakdown voltage is the minimum voltage required to cause a dielectric material to lose its insulating properties and become conductive. It is important because it determines the maximum voltage that can be applied to a material before it breaks down and becomes damaged.
2. How does field uniformity affect breakdown voltage?
Field uniformity refers to the evenness of the electric field within a material. In general, a more uniform electric field will lead to a higher breakdown voltage because it reduces the concentration of high field regions that can cause breakdown.
3. What factors can affect field uniformity?
There are several factors that can impact field uniformity, including the shape and thickness of the material, the type of voltage applied, and the presence of any defects or impurities in the material. Additionally, external factors such as temperature and humidity can also affect field uniformity.
4. How can field non-uniformity be measured?
Field non-uniformity can be measured using various techniques such as electric field mapping, charge sensing, and optical methods. These methods involve creating a visual representation of the electric field within a material and identifying any areas of non-uniformity.
5. Can field uniformity be improved to increase breakdown voltage?
Yes, field uniformity can be improved through various methods such as using materials with higher dielectric constants, optimizing the shape and thickness of the material, and reducing the presence of defects or impurities. Additionally, careful design and engineering of the material can also help improve field uniformity and increase breakdown voltage.
  • Electrical Engineering
  • Classical Physics
