Breaking Distance of a Car Traveling on an Inclined Plane
In summary, the problem involves calculating the braking distance for a car traveling at 35.0m/s down a hill at a 10.0 degree angle relative to the horizontal. The teacher explained that the total force acting on the car during braking is equal to the original acceleration (a) of the car minus the force of gravity (mgsin10). However, it is unclear how to find the original acceleration or why it is used to calculate the braking force. Additionally, the effect of the angle on the braking force depends on whether the car is skidding or the tires remain rolling. More information, such as the mass and normal acceleration, is needed to solve the problem.
Emma Hughes
Calculate the braking distance for a car traveling at a speed of 35.0m/s down a hill at an angle of 10.0 degrees relative to the horizontal.
F=ma
v=u + 2as[/B]
The teacher briefly explained this in class saying that the total force acting on the car when the braking force is applied (with direction of braking force as positive) is: ma - mgsin10, with a being the original acceleration of the car.
Although I don't understand how to get the original acceleration of the car or why it is used to get the braking force of the car.
F=ma
v=u + 2as[/B]
I think that ##a## here is the deceleration of the car by braking on a horizontal road. Hence ##ma## is the braking force of the car.
On an incline you have gravity accelerating you, which is the second term in the equation.
Note that in this model it is assumed that the braking force of the car itself isn't affected by the angle. You might like to think about this and why in a more sophisticated model this may not be the case.
Likes scottdave
Whether the angle affect the braking force would depend on if the car is skidding (kinetic friction between tire and road) or the tires remain rolling (static friction between road and tire).
Reading the problem statement - the mass is not given, nor the "normal" acceleration.
So more information is needed to solve this.
FAQ: Breaking Distance of a Car Traveling on an Inclined Plane
1. What is the breaking distance of a car traveling on an inclined plane?
The breaking distance of a car traveling on an inclined plane is the distance it takes for the car to come to a complete stop after the brakes are applied. This distance is affected by various factors such as the speed of the car, the angle of the incline, and the condition of the road surface.
2. How does the speed of the car affect the breaking distance on an inclined plane?
The speed of the car has a direct impact on the breaking distance on an inclined plane. The higher the speed, the longer the breaking distance will be. This is because the car will have more momentum and it will take longer for the brakes to slow down and stop the car.
3. Does the angle of the incline affect the breaking distance of a car?
Yes, the angle of the incline does affect the breaking distance of a car. The steeper the incline, the longer the breaking distance will be. This is because the force of gravity pulling the car down the incline will add to the car's momentum, making it harder for the brakes to stop the car.
4. Is the breaking distance of a car on an inclined plane different from that on a flat surface?
Yes, the breaking distance of a car on an inclined plane is different from that on a flat surface. This is because the incline adds an additional force to the car, making it harder for the brakes to stop the car. Additionally, the angle of the incline and the condition of the road surface can also affect the breaking distance.
5. How can the breaking distance of a car on an inclined plane be reduced?
The breaking distance of a car on an inclined plane can be reduced by adjusting the speed of the car, using the brakes properly, and maintaining a safe distance from other cars. It is also important to regularly check and maintain the brakes and tires of the car to ensure they are in good condition.
