MHB Brie's question from Facebook (finding equation of perpendicular line)
Brie is seeking assistance with finding the equation of a perpendicular line to y = 3x + 3, using the ordered pair (1, 1). She correctly applies the slope-point formula and derives the equation y = (-1/3)x + (4/3), but notes that the graph does not pass through (1, 1). A response confirms her calculations are accurate, showing that when x = 1, y indeed equals 1. The issue may lie in the graphing method or device used. Overall, her approach is validated, and the perpendicular line is correctly identified.
Jameson
Insights Author
MHB
Brie writes:
Hi everyone! I need a little help with finding a perpendicular line using an ordered pair and the equation to the previous line.
The equation is y= 3x+3 and the ordered pair is (1,1).
So far, I've used the slope-point equation to come up with such:
y-y1=m(x-x1)
y-1= -1/3(x-1)
y=(-1/3)(x)-(-1/3)(1)+1
At the end I ended up getting:
y=(-1/3)x+(1/3)+1
y=(-1/3)x+(4/3)
When I graph it, it's not going through the point (1,1) which it should. What am I doing wrong?
Thank you!
Mathematics news on Phys.org
Re: Brian's question from Facebook (finding equation of perpendicular line)
Hi Brie, (Wave)
You have solved the problem correctly actually! :) When you plug-in x=1 to your final equation you get [math]y=-\frac{1}{3}(1)+\frac{4}{3}=\frac{4}{3}-\frac{1}{3}=\frac{3}{3}=1[/math], so $y=1$ like we want it to.
If you graph it as well you can see the right angle it forms. What device are you using to graph the equation? Perhaps there is a small error with inputting the equation.
[GRAPH]yua730csio[/GRAPH]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
