I Bubble universes and physical constants
In the context of bubble universes and eternal inflation, new universe creation occurs only during the inflation phase of the original universe, and once a bubble forms, it no longer inflates. Physical constants may differ across bubbles, but this is a speculative aspect of the theory, and the existence of Planck constants at the early inflation stage depends on the specific model. The matter in our universe does not originate from the eternally inflating region; instead, it is created from energy transferred from the inflaton field during the bubbling process. The inflaton field's energy density is relatively constant in the inflating region, but decreases rapidly when a bubble forms, allowing for the transition to ordinary matter and radiation. Overall, the dynamics of eternal inflation suggest that matter is continually generated without depleting resources from the inflating region.
JuneSpring25
TL;DR Summary
A question about bubble universes and physical constants
Hello, couple of questions about bubble universes and the physical constants. I understand in an eternal inflation scenario universes bubble off the original during the inflation phase. Firstly, according to this theory, does the new universe creation only happen at an early inflation phase of a universe - before the phase we are in within our current observable universe (or bubble)?
Secondly, I understand that the physical constants would be different in different bubbles. Would the Planck units be different or would these be the same since the universes begin in the same space time?
Also if the eternal inflation theory continually creates new universes from one universe, why don't we eventually run out of matter for new bubble universes?
Thanks for any answers!
Space news on Phys.org
Answers to your questions are educated guesswork.
Likes MathematicalPhysicist
If you mean, could our universe bubble off another one according to this theory, no. New universe creation in eternal inflation models (at least as I understand it) only happens in the inflating portion of the spacetime; once a new universe is "bubbled off", it is no longer inflating.
I think this is a speculative property; it doesn't necessarily have to be the case in an eternal inflation model, although many such models seem to include it.
It doesn't, at least not the way you are using the term "universe", namely, to mean one of the "bubbles" after it gets formed, like our universe. The eternally inflating region of the overall spacetime is not a "universe" in this sense.
The matter that is in a universe like ours does not come from the eternally inflating region as matter. Part of the process of a new universe "bubbling off" from the eternally inflating region is that "matter" and "radiation" (the quantum fields in our Standard Model of particle physics, quarks, leptons, gauge bosons) are "created" from energy that is transferred from the inflaton field (the field that drives eternal inflation). The eternally inflating region contains no matter or radiation; all of its energy density is stored in the inflaton field.
Likes JuneSpring25 and PeroK
In terms of what eternal inflation models say, no, most of them are not: the models give well-defined answers to most of them. Whether those models will actually turn out to be correct is a different question.
Likes JuneSpring25
Thanks, I appreciate the answers, that's really helpful. Would the Planck constants be different in these different bubbles? Do the Planck constants exist at the early inflation stage?
Depends on the model.
If you mean, is there anything corresponding to "Planck's constant" in the eternally inflating region, again that depends on the model.
Likes JuneSpring25
@PeterDonis I don't know much about eternal inflation, but if it's anything like slow-roll, then isn't the energy density of the inflaton field roughly constant (only very slowly changing) with time? If so, then couldn't the OP's question be reformulated as something like, "why is the total energy associated with the scalar field able to increase without bound, as space expands in the eternally-inflating region?" I realize the answer could be just, "because that's how physics works, according to these models." But I thought I'd ask if this was another valid way of looking at it.
In the region of spacetime that is inflating (which in eternal inflation models is everywhere that isn't inside a "bubble" that has turned into an ordinary universe like ours), yes. But when a "bubble" forms (a region that turns into an ordinary universe like ours), it is because the energy density of the inflaton field decreases rapidly, and that energy density gets transferred to (at least in our universe) the Standard Model fields. Specific inflation models differ on exactly what causes that transition.
The "why don't we eventually run out of matter" part could, I suppose. But the answer is still basically the one I gave in post #3. The short version is that there is no global "conservation of energy" in GR, and in particular there isn't in the spacetimes being considered in inflation models.
PeterDonis said:
In the region of spacetime that is inflating (which in eternal inflation models is everywhere that isn't inside a "bubble" that has turned into an ordinary universe like ours), yes. But when a "bubble" forms (a region that turns into an ordinary universe like ours), it is because the energy density of the inflaton field decreases rapidly, and that energy density gets transferred to (at least in our universe) the Standard Model fields. Specific inflation models differ on exactly what causes that transition.The "why don't we eventually run out of matter" part could, I suppose. But the answer is still basically the one I gave in post #3. The short version is that there is no global "conservation of energy" in GR, and in particular there isn't in the spacetimes being considered in inflation models.
That's more or less what I expected but helpful to hear, thanks. Thanks also for the clarification about what happens to the energy density of the inflaton field as part of "reheating."
