Bucklig: deflection at Euler load
The discussion revolves around calculating the horizontal deflection of a vertically clamped beam subjected to both horizontal and vertical forces. The initial calculations suggest that the deflection does not diverge when the vertical load exceeds the Euler buckling load, which is unexpected. It is noted that the Euler buckling load formula typically applies to axial loads only, and modifications are necessary when lateral loads are involved. The conversation highlights the need for further research into beam-column analysis methods to accurately assess deflection under combined loading conditions. Understanding these principles is crucial for proper structural analysis and design.
Jef124
Hello
I was trying to calculate the horizontal deflection of the free end of vertical clamped beam. The beam would be loaded at the free end with a horizontal force H and a vertical force P. My idea was to calculate an initial deflection due to the force H. Then calculate the additional deflection due to the previous deflection and the force P. I'd expect that when the force P is bigger than the Euler buckling load that the deflection would diverge but that's not happening when I try to calculate this.
I tried it on a beam with a length L of 6 m, stiffness EI = 1476600 Nm^2 (E=69 GPa, I=2140 *10^4 mm^4, H=1 kN. I calculated that the Euler buckling load P_{cr}=(Pi)^2EI/(2L)^2=101,20 kN and used a way bigger P=5000 kN.
For the initial deflection I used v_0=(1/3EI)HL^3=4,87607 *10^{-5} m. For the next iteration steps I used v_i=v_0 + (1/3EI)L^2P*v_{i-1} which eventually converges to v=5,08259 * 10^{-5} m instead of diverging.
I know 5000 kN isn't a realistic value and that the beam would probably yield with such a high load but shouldn't this diverge?
Also for loads smaller than the Euler buckling load, is this the right way to calculate the deflection? If not what would be a good way then?
Thanks in advance
Jef124 said:
Hello
Thanks in advance
I'm just taking a quick glance at the situation you are trying to analyze here.
The usual formulas for the Euler buckling load are derived assuming that the only force applied is applied in the axial direction. I think the situation you are describing here is for what is called the buckling of a beam-column, since lateral and axial loads are being applied simultaneously to the tip of the cantilever. The Euler critical load must be modified in this case over that calculated for a simple column with no loads applied in the lateral direction.
There are methods for analyzing such beam-columns, but it will take a little research to confirm what is required.
Further to the discussion in Post #2 above, this article discusses the effect on the deflection of a laterally loaded member caused by an axial load. See pp. 5-6 for a discussion of the effect:
I didn't realize I couldn't use Euler buckling for my situation. Thank you!
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
