Build Parallel Basic Circuits with Affordable Capacitors | Learn How Here!"
  • Thread starter Thread starter caljuice
    Capacitor Type
To build parallel basic circuits with capacitors, it's essential to understand that "parallel" refers to the circuit configuration rather than a capacitor's inherent properties. Key specifications for selecting capacitors include voltage rating, whether they are bipolar, and their capacitance value. Affordable options can be found at online electronic stores, but specific models weren't mentioned in the discussion. Using alligator wires to connect the capacitors to a battery is a practical approach for beginners. Understanding these fundamentals will help in successfully assembling simple circuits.
caljuice
Sorry this might be kind of vague. So I want to learn how to build parallel basic circuits with parallel capacitors. I was unable to build it properly during my lab. Basically I'm going to get alligator wires and clamp them to a battery and the capacitors. Looking online at some online electronic store, there's a gazillion capacitors. Is there any cheap specific name/models of parallel capacitor I should get just to learn how to get a simple circuit going.
"Parallel" refers to the position where a capacitor is in a circuit, it's not a property of a capacitor in itself.
When specifying a capacitor, the three most important basic properties is how high of a voltage you can put on it, if it's bipolar or not, and what the capacitance is.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
