Building a 24V AC and 0-30V DC Power Supply: Tips and References
The discussion focuses on building a power supply that outputs 24V AC and 0-30V DC using a 220V/24V transformer. Users emphasize the importance of safely integrating the 24V AC from the transformer and highlight the challenges of achieving stable DC output from the AC signal. It is noted that simply rectifying the 24V AC may lead to poor voltage regulation, especially under load, due to the transformer’s resistance. Suggestions include using a fuse for safety and experimenting with a choke input filter to improve regulation. Overall, the conversation underscores the complexity of combining AC and DC power supply designs.
Bassalisk
Hello people!
I've been absent from this forum for quite a while. But now I return with questions regarding a little project I have to do.
So basically I have to make a AC and DC power supply. I need 24 V AC output and 0-30 V DC power supply.
I have a transformer(I think its 220V/24V) which i plan on using to build such power supply
I have some circuits in mind, but I have no clue how to use 24V AC safely from transformer. So basically I would have to combine 2 different designs for DC and AC. I found some projects for 0-30 V variable but they don't cover AC supply.
Can anybody give me some references or schematics or pointers on how I can make such power supply?
Thanks
Just fuse the 24VAC. Get the fuse rating from the transformer specs.
You will have to jump through some hoops to get 30VDC from a 24VAC signal. It will not be as easy as just using a rectifier and regulators.
Well i figure if 24V AC is a effective value and the amplitude of the sine wave I am rectifying is 24\cdot \sqrt{2} then that comes to about 33.94 V sine wave amplitude. If i rectify that I should get enough voltage for DC.
So a fuse will do a trick? Ok, I am gone shoppin!
You'll notice poor regulation at high DC output
but you should be able to get your 30 volts at not much current, maybe even 32 or 33
because the transformer is rated 24 volts at substantial current, probably makes 25 or 26 at zero current
reason regulation is bad is this:
With capacitor filter the current is delivered in big gulps near sinewave peak, so voltage drop along transformer's resistance is more than you'd expect. So peaks get 'flattened' as current goes up.
We learn best by doing and figuring out the complications that arise along the way ...
Experiment with a choke(inductive) input filter if you can - regulation will be better but voltage a bit lower...
old jim
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
