Building a Picture Frame Music Player with an iPod
A visual artist is creating a project that combines sound with a photograph in a picture frame, using an iPod as the audio source. The challenge is to fit a speaker and a battery-powered amplifier within the two-inch depth of the frame. The artist is seeking recommendations for suitable components that can deliver good sound quality without being too large or small. There is interest in exploring powered speaker systems designed for the iPod, but they may not meet the size and sound quality requirements. The project aims to seamlessly integrate audio into the visual display.
klebe21
Hello I'm a visual artist and I'm trying to make a project were I need to add a sound to a photograph hang to a wall in a picture frame.The source of the sound it will be a ipod (unless someone has a better idea)I need to build a device to make the music from the ipod place in the narrow place beyond the frame(two inches deep) .I can find the speacker but I have not idea what should I put betw. the speacker and the ipod. I guess some kind of amplifier battery powered.(speacker and amplifier/battery must to plabe beyond the frame)
Thank you
Klebe21
Thank you
Klebe21
Welcome to the PF. What is your power source going to be? Batteries, or do you have another source of power?
There are powered speaker systems for the iPod -- have you looked at those already?
Hello,I know about the speacker that are working with ipod,but are too small(no good sound )or too big for what I need. About the power ,if I can get decent sound with battery I prefer ,but I'm flexible.
Thank you
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
