Building a Ski Rope Tow. Need help with motor sizing
The discussion focuses on building a homemade ski rope tow and the challenges of motor sizing and torque calculations. The project specifications include a 300-foot hill at a 20% grade, a 650-foot long rope weighing 200 lbs, and the desire to pull three 200 lb people simultaneously at a speed of 7-10 fps. Calculations suggest using a 15:1 gear reducer with a 14" pulley, yielding an output speed of 7.1 fps, but concerns about motor overload and safety are raised. Recommendations indicate that a 2 HP motor may be necessary to accommodate load and friction, as well as the importance of implementing safety features to prevent accidents.
JesseWendt
Need help with motor sizing/torque calculation - Building a Ski Rope Tow.
I am building a homemade ropetow in my backyard. I have done a lot of research and unfortunately I have been away from physics for about 15 years, so I am having trouble calculating my motor size and transmission options. I will lie out what I am trying to accomplish below.
Here are the specs:
-The hill is 300 feet long at a 20% grade
-The rope is approximately 650 feet long and 200 lbs.
-I can use anywhere between a 1 to 2 hp motor operating at 1750 RPMs (would prefer to stay on 110 power and definitely can't go to 3 phase)
-The gear reducer can be 10:1 15:1 or 20:1
-The pulleys to attach to the output shaft range from 6" to 14" mostly in even numbers.
-I would like to be able to pull three 200 lb people up said rope at once
-I would like the rope speed to be approximately 7-10 fps.
I am open to ideas. I have nothing purchased at this point.
My plan was to use a 15:1 reducer with a 14" pulley for speed that works out to
1750rpm/15 = 116.667 RPM output
circumference of pulley is 3.663'
speed is 427.39011 feet/minute or 7.1 fps
This would be completely fine for speed if it can handle the load. My biggest concern is not overloading the motor.
Any help or suggestions would be appreciated.
Jesse
Not to be a wet blanket, but have you considered any kind of fail-safe or cut-off? As a kid, I saw a young girl get hauled up the mountain because her long hair got entrapped in the tow-rope. Not really fun.
Rope-tows are inherently dangerous if used with standard twisted ropes. It may be possible to source some braided ropes, such are used on paper machines, and that could help with the safety issue. Teufelberger makes braided ropes, for instance.
Yep. I have that covered with switches at the top and bottom and a trip line that will kill the motor.
Sorry I work in metric..
600lbs is about 300kg
300ft at 20% is about 60ft or 20 meters
300/10 = 30 seconds
Power = energy/time = mgh/t = 300*9.8*20/30 = 1960W = 2.6bhp
That's the power required to lift the weight of the people up the hill in the stated time assuming no friction, so the actual power required is going to be significantly more than that.
I've no data on the force required to pull a skier through snow.
PS: Also need to account for losses in the motor and gearbox etc.
Seems a little fast to me. Tow lifts I've seen go less than half of that.
But if these are the metrics you insist on, you should expect about 0.6HP per 180lb person. But since the pull is unlikely to be even, I'd go with a 2HP motor to be safe.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
