Bulbs that only emit long IR (>1200nm) or 1000K color temp.
The discussion revolves around finding bulbs that emit long infrared wavelengths (greater than 1200nm) or have a color temperature between 500K and 1000K. Participants suggest using dimmers to reduce voltage on bulbs, which can lower color temperature, but note that filament lamps may waste power. LED options are recommended for their efficiency in producing infrared light, with some specific products mentioned. However, concerns are raised about the radiant power of LEDs, particularly for high-demand applications. The conversation emphasizes the need for clarity on the intended application to determine the best lighting solution.
nlis12
I am looking for bulbs that would be emitting a spectrum characterized by a color temperature of between 500K and 1000K or any kind of light fixture that only emits long IR wavelengths.
Does such a thing exist?
How about reducing the voltage on the bulb until it just glows, maybe using a dimmer? I have done this with 12 volt bulbs in school science when demonstrating the Greenhouse Effect.
Likes nlis12
You can buy IR lamps for use with night vision and security equipment. LED s seem to be the way to go. Here's an example I found.
Likes nlis12
Thanks!
That makes sense, if there is less voltage, less power, so the color temperature should go down.
nlis12 said:
Thanks!
There may be a lot of wasted power in using a filament lamp in that way. LEDs will give you much more IR at the wavelengths you need.
Likes nlis12
Thanks for the info, I'll look up more stuff related to this!
Yea I thought about that, but LEDs don't give me the radiant power I need. (unless I had >100,000 of them)
Likes sophiecentaur
You can get 14W IR LED lamps. What was your application for 1.4MW of IR? Also, where would you get appropriate filament lamps?
I think for this you are talking in the range of an infrared heater. I remember once using an infrared heater to illuminate a room for a camcorder with an ir mode.
Likes Asymptotic and dlgoff
Good idea. They also can provide lots of watts.
What sort of spectrum do you require? If it's got to be Black Body then a hot black body (filament) will do nicely. If you want no visible light from your source then you may need to use a filter - which is what night vision sources tend to do. But you haven't said what your application is.
Likes dlgoff
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 19 ·
17K
