Bulk Drive v2.0: FTL & Interuniversal Travel?
  • Thread starter Thread starter Toastus
    Drive
Toastus
I have absolutely no idea how to do this, but tell me if it will theoretically work:
Somehow 'slice' the membrane around you into a little membrane bubble you float on, then move it around in Bulk space until you get to where you want to go, then rejoin it with the membrane to get back into this universe.
Can you slice a membrane?
Is it possible to move FTL in Bulk space?
Can you rejoin your bubble brane into our own universe?
If that works, it would be a great method of FTL travel and interuniversal travel.
You can start out intuitively. Suppose you are a bug living on a very large soap-film surface, and you want to set it shaking so that a soap bubble will break off with you inside. That is a lower-dimensional version of what you might want to do - create a hyperspherical bubble of brane-space that breaks off from your home-brane and travels into the bulk. The basic way to change the local curvature of a brane is to gather mass in the one place. What you want is to have a sort of three-dimensional "black shell" (like a black hole, but with a spatially extended singularity shaped like the surface of a sphere, rather than being just a point) form, with you inside it.
So let's suppose you had some way of forming a black hole of a certain radius (by shepherding enough mass into the same volume of space, until gravitational collapse took over). You could try to do that simultaneously at a multitude of points surrounding you, with the points close enough that the event horizons of the new black holes overlapped. The black shell would be made up of a large number of black holes that formed simultaneously. It seems that for this to work out, you would have to have lots of matter streaming towards you from every direction simultaneously - and then you time it all very precisely so that the black shell forms while it's all still a finite distance away, rather than part of it falling all the way into where you are located and destroying you.
This would definitely require engineering on a cosmic scale, e.g. stars being steered around (see "Shkadov thruster"), and flows of interstellar nebulae being planned in advance. It sounds like something that would require thousands of light-years and millions of years at the very least. Then even if you managed to break off a bit of brane, you'd have to worry about internal gravitational shockwaves from its creation destroying you. And then suppose you do meet another braneworld after an unknown time passing through the bulk, if it doesn't know you're coming, I see no guarantee that collision will be friendly.
What I just sketched is probably the crudest and most naive way of thinking about how this would work. Maybe there are gentler ways to break off a branelet in a controlled fashion, or maybe the whole thing can be ruled out by "energy condition" theorems (of the sort which pose problems for the existence of wormholes). But there's certainly no reason to think that FTL is possible in the bulk. Bulk space is just ordinary space.
Also, another thing to bear in mind is that braneworld models are not limited to 3D branes. You can have several branes of higher dimension which intersect in a 3D region, and then have strings connecting the branes which are confined to that region, and you'll have an effectively 3D space. In that case travel between braneworlds might involve staying on one of the branes but somehow getting away from the intersection zone.
So a brane travels through the Bulk at sublight speed? Taking trillions of years to move a bit?
If it's massless, it can travel at light speed, but no faster. Special relativity still applies everywhere in string theory, on the brane and in the bulk.
Fartbiscuits...
Do branes bend? If so, would it be possible to go between the two points like a wormhole?
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
this thread is to open up discussion on Gravi-GUT as theories of everything GUT or Grand Unified Theories attempt to unify the 3 forces of weak E&M and strong force, and Gravi-GUT want to add gravity. this peer reviewed paper in a journal on Gravi-GUT Chirality in unified theories of gravity F. Nesti1 and R. Percacci2 Phys. Rev. D 81, 025010 – Published 14 January, 2010 published by Physical Review D this paper is cited by another more recent Gravi-GUT these papers and research...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
