Undergrad Bullet Cluster explained without 'dark substances'
The discussion centers on the Bullet Cluster and its implications for dark matter, proposing that supermassive black holes could explain observed phenomena without invoking dark matter. It argues that these black holes, being less affected by collisions, would accumulate at the edges of the clusters and contribute to weak gravitational lensing. Critics challenge this view, asserting that supermassive black holes constitute a minuscule fraction of a galaxy's mass and cannot account for the mass distribution observed in the Bullet Cluster. They emphasize the need for scientific references and mathematical modeling to support such claims. Ultimately, the debate highlights the complexities of explaining cosmic phenomena without relying on dark matter.
Delisso
TL;DR
Mass distribution in Bullet Cluster has an explanation without dark matter. The Supermassive black holes would accumulate at the edges of collision.
The Bullet Cluster counts as 'smoking gun' for the dark matter. But what lacks in these calculations is the super massive black holes at the center of almost every galaxy. As the most massive and most compact objects in the collision, it's expected that they are less slowed down by the collision than gas and stars. As a result they will accumulate at the edges of the colliding clusters. Super massive black holes are expected to create the observed weak gravitational lensing.
  • Skeptical
Likes PeroK
Space news on Phys.org
A distribution different from that would be weird.
Delisso said:
Summary:: Mass distribution in Bullet Cluster has an explanation without dark matter. The Supermassive black holes would accumulate at the edges of collision.
Interesting, but you need to give a reference (or references) for research on this.
Supermassive black holes constitute only a tiny fraction of a galaxy’s mass (estimated as a few parts per million in the case of the Milky Way for example). Thus, your explanation is dead on arrival.
You are also missing any actual scientific reference and therefore in possible violation of forum rules.
1- The mass distribution attributed to the galaxy is calculated with the assumption that dark matter exist. It's not the real mass.
2- A supermassive black hole will land outside of the gas and stars as they are not slowed down by other material. Their momentum is enormous.
3- The supermassive black holes would create weak lensing.
These 3 points combined easily explain the picture without assuming dark things.
Likes Orodruin
It does not. Visible mass means gas and stars. Offset is caused by black holes' accumulation out of the visible matter.
As @PeroK has already pointed out, your references do not make these claims. Indeed, they say the evidence shows that there is dark matter. They certainly do not say that supermassive black holes can account for the data without assuming dark matter.
Do you have any references that support the claims you are making about supermassive black holes being able to account for the data without assuming dark matter?
These are very strong claims that would need detailed mathematical modelling to back them up. Where is this published?
I'm objecting these papers.
The logic is easy: Accept the solution with the least assumptions.
Facts:
1- Supermassive black holes would accumulate at the end of the collision
2- Supermassive black holes would cause weak lensing.
These 2 facts are enough to explain the observed phenomena.
  • Skeptical
Likes PeroK
Do it. I'm throwing it here exactly for that reason.
Delisso said:
Do it.
Not what this forum is for. Do it yourself and publish it - then we can talk.
Likes pinball1970
I'm not writing papers.
  • Haha
Likes PeroK
The ratio of normal mass to dark matter is not that large. Even if you allow for a factor of 1000 (which is waaaay too much), you would still be another factor of 1000 away from the supermassive black hole even being close to the galaxy mass. Your ”explanation” simply does not stand up to basic scrutiny because you just don’t know the most basic of facts related to this subject.
Likes berkeman and phinds
To add to that, black holes would constitute so called MACHOs, which have been largely ruled out as an explanation for dark matter.
That's not what this forum is for.
Then we're not discussing your personal theory.
Thread closed.
Likes Motore, Bystander and PeroK
  • · Replies 134 ·
11K
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 18 ·
