Burgers Equation Question - cannot satisfy initial conditions
zapz
Burgers Equation Question -- cannot satisfy initial conditions
Use characteristics to solve u_t+uu_x=0 on half line x≥0 with u(x,0)=x^2
NA
I think I have an issue with the initial condition. So solving via characteristics gives:
\frac{dx}{dt}=u \Rightarrow x=ut+x_0 \Rightarrow u=f(x-ut). Then we plug in initial values and get:
u(x,0)=f(x)=x^2 \Rightarrow u=(x-ut)^2 \Rightarrow u^2t^2-u(1+2xt)+x^2=0
Then by quadratic formula
u=\dfrac{(1+2xt) \pm \sqrt{(1+2xt)^2+4x^2t^2}}{2t^2}
Now here I have a problem. So, in order to pic which sign solution to use, I need to use the initial condition. However, at t=0, I have an obvious problem. If anyone could offer help, or whether there is a typo in the problem, that would be much appreciated!
What is the limit as t→0+?
Likes 1 person
Thank you for a quick reply! I just did the limit out and that resolved my issue. Thank you very much!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
