BWR RIA during nuclear heating
In summary: More detailed analyses are needed.In summary, it seems that the recent developments in BWR fuels (increased enrichment, added uranium mass at the bottom, part-length fuel rods especially in the corners) have changed the control rod reactivity values in such a way that the potential reactivity insertion caused by the postulated rod drop accident is potentially quite high at certain points during nuclear heating. More specifically, at the stage when CR:s adjacent tho those already withdrawn are being taken out of the core. This may result into quite large reactivity insertions and it is not trivial that the RIA limits of fuel are fulfilled at every point (up until the spectral effect finally cuts the CR reactivity values), if the situation has not been
rmattila
244
It seems that the recent developments in BWR fuels (increased enrichment, added uranium mass at the bottom, part-length fuel rods especially in the corners) have changed the control rod reactivity values in such a way that the potential reactivity insertion caused by the postulated rod drop accident is potentially quite high at certain points during nuclear heating. More specifically, at the stage when CR:s adjacent tho those already withdrawn are being taken out of the core. This may result into quite large reactivity insertions and it is not trivial that the RIA limits of fuel are fulfilled at every point (up until the spectral effect finally cuts the CR reactivity values), if the situation has not been considered thoroughly at some stage during the gradual fuel development.
I was wondering if someone else has come up with this issue, and if there are some findings that might be of interest? Especially the behaviour of Doppler and other feedback mechanisms during the heating phase would be interesting. I am planning to do some generic calculations on my own, but it would be nice to know if someone has already done something in this direction.
Yes, that is a very good report concerning the consequences of the postulated CR drop. However, even there on page 143 it is suggested that analyses are performed either at CZP (where the enthalpy rise has traditionally been limiting) or at HZP (which has traditionally been close to the maximum reactivity insertion point). What I'm mainly concerned is the validity of using only these two points, as it seems that the most limiting point might actually lie somewhere in between, or perhaps at a few % power, depending on the reloading pattern and the withdrawal sequence.
There are two competing effects: the CR worth, which tends to be the largest at a certain point rather late in the in the withdrawal sequence, and the negative feedbacks, which are more effective at increased temperature. Using just the CZP and HZP points in the analyses might fail to catch the most limiting transient.
Related to BWR RIA during nuclear heating
1. What is a BWR RIA during nuclear heating?
A BWR RIA (Reactivity-Initiated Accident) during nuclear heating is a type of accident that can occur in a boiling water reactor (BWR) where the power level increases rapidly due to an increase in reactivity, often caused by a sudden change in reactor conditions.
2. What causes a BWR RIA during nuclear heating?
A BWR RIA during nuclear heating can be caused by a number of factors, including control rod malfunction, fuel rod failure, or a sudden change in water flow rate or temperature.
3. How does a BWR RIA during nuclear heating affect the reactor?
A BWR RIA during nuclear heating can lead to a rapid increase in reactor power, which can potentially cause fuel and structural damage, as well as the release of radioactive material.
4. How can a BWR RIA during nuclear heating be prevented?
To prevent a BWR RIA during nuclear heating, strict control and monitoring of reactor conditions is necessary. Regular maintenance and testing of control and safety systems is also important in preventing such accidents.
5. What are the potential consequences of a BWR RIA during nuclear heating?
The consequences of a BWR RIA during nuclear heating can range from minor damage and release of radioactive material to a more serious meltdown or core breach, which can have significant environmental and health impacts.
  • Nuclear Engineering
12K
