C as the speed of light and the speed of sound in Michelson-Morley.
GerryB
The symbol, c, represents both the speed of light and the speed of sound in most scientific reference texts. Can the speed of sound be substituted for the speed of light in the Michelson-Morley (MM) formula: T = [L / (c - v)] + [L / (c + v)]?
Consider an observer on a train of length, L. It is moving with a constant velocity, v, along a level straight section of track. Can this observer find the train’s velocity relative to the embankment (Earth), with a single clock? That is, if there is an inertial reference frame attached to the moving train, and another inertial reference frame, with another observer, attached to the Earth (which is considered at rest), can the caboose observer find the train’s relative velocity? Will this value be in the form of the simplest law of motion: v = d / t, or in a form that violates the classical principle of relativity? Alternatively speaking, will the two observers, one in motion and one at rest, measure two different values (via Galilean transformation) for the velocity, v of the train. Or, is it possible for them to measure the same value, v?
It is a windless day (air, medium at rest). The observer is in the caboose with a lantern to signal the engineer in the locomotive. When he sees the flash of light (effectively instantaneous at this distance), he blows the whistle. She starts her clock at the same moment she sends the light flash, and thusly she can measure the time, t, for the sound wave of the whistle to travel along the length, L. When the sound wave reaches her, she flashes the lantern once more. An observer at rest on the platform sees the first flash and the second flash, and with his clock measures the time between these flashes. Will each observer measure the same time, t, between the two flashes?
If the platform observer has a means to establish the distance between the flashes (by some landmarks running parallel to the track, for example). The length of the train is obtained from the specifications; the constant velocity of sound in still air is agreed upon amongst the observers; their clocks are mechanically similar. Will he then be able to determine the same velocity for the train? Will these two observers use the same formula: L = ct + vt? This formula describes the idea that as the sound wave (velocity, c) travels rearward, it meets the caboose (velocity, v) traveling forward during the sane time. Each begins at the endpoints of the distance, L. This formula can be rearranged to the MM form: L / (c + v) = t; v = [L / t] - c, to find the velocity of the train relative to the earth.
Welcome to PF;
If you used sound interference, I suppose you could use the same equation over short distances.
Not sure if you could use the exact formula because sound waves work a bit differently to light.
You will not get the null result that you get for light because the speed of sound is frame dependent and there is no intrinsic problem with objects (the train say) going faster than the speed of sound.
You should be able to work out the answers to your questions using normal Galilean relativity, since the relative speeds are very slow. If you want to explore the special relativity with sound pulses, you will need to postulate a very fast train to see the effects... recall that sound is usually non-relativistic.
Thanks for your response Simon:
I was just mainly concerned whether the substitution was valid. If it is valid, then sound could be substituted for light in ANY formula involving c. I was not thinking about doing an interference experiment, but using the formula of one arm of interferometer as a replacement for the echo formula.
As you say, "...relative speeds are very slow," but I think that is precisely what I want. I apologize that this might be a new theory, but I am mostly just exploring ideas as a mental exercise. I will try to more properly phrase my questions in the future.
You could, in principle, make an acoustic interferometer. It would allow you to detect any anisotropy in the speed of the air flow through the interferometer.
The main difference between sound and light is that the speed of light is invariant whereas the speed of sound is not.
Yes DaleSam, I was struggling to set up the train as the one arm of the interferometer. Then, use a clock to time the sound wave traveling through still air (medium). I think that sound waves are invariant under certain conditions such as this. I was just looking for a second witness on the validity of the substitution.
The speed of sound waves are never invariant.
But a MM type interferometer does not detect invariance. It detects isotropy relative to the apparatus.
We may have to agree to disagree. The speed of the sound is independent of the speed of the source of the emitter of the the wave, like light. When the source and receiver are traveling in tandem, and their motion is disconnected from the medium, then I am supposing that the MM formula would apply. But this only works if the speed of sound can be substituted for the speed of light, all be it on a very local scale. I will try to narrow my question.
This is not a matter of opinion where two people can express different but equally valid opinions.
Yes. This is true, but it is also not what invariance means. Invariance is when different inertial frames agree on a quantity.
There can logically only be one invariant speed, and experiments show that it is the speed of light, not sound.
The speed of sound waves is constant with respect to the air through which they are moving. Therefore, that speed cannot be invariant, because the speed of the air is not invariant.
No. That is not correct.
Light and sound do not always follow the same equations.
Likes 1 person
Ah Simon, this is what I am looking for, to which equations can both light and sound be applied? At the slow speeds of sound waves, Special Theory relativistic effects should be negligible.
The Earth drags a several miles thick layer of atmosphere along with it as it hurtles through the galaxy. So, the air / medium moves with the earth, fortunately for us.
Let us assume that air near the surface of the earth, in the vicinity of the train, behaves uniformly in all directions when sound waves pass through it, isotropy. I am not worried about the behavior of the medium at this point, except that the air molecules do not share in the motion of the train.
On a windless day, through an open window, the train observer in the moving reference frame will hear the same sound wave moving at the same speed as the platform observer in another reference frame at rest.
By Doppler, the troughs and crests of the wave will stretch out near the engine whistle, but compress near the caboose observer by an equal amount due to the tandem motion of the train. They thus cancel out, so that there is no change in frequency for the train observer. For the platform observer there is a change in frequency, but each observer will not notice any change in the wave speed in the same still air, by definition. The sound wave will have no velocity added to it by the moving source. They will agree on the speed of the sound wave, though their reference frames are in motion relative to one another .
He will not, because on a windless day the train observer will not experience still air outside the window; there's a strong wind blowing towards the rear of the train. The platform observer doesn't experience that wind (because it's a "windless day", right?).
Suppose the length of the train is ##L##, the speed of the train relative to the air (and thus the the platform) is ##v##,and the time between emission of the sound at the front of the train and detection of the sound at the rear of the train is ##T##. The train observer will calculate the speed of sound to be ##L/T##, just by using the simple formula that speed equals distance traveled divided by time. The platform observer, using the exact same formula, finds that the speed of sound is ##(L-vT)/T##.
Note that this has nothing to do with the motion of the source; it's irrelevant whether the sound is produced by something on the front end of the train or something on the ground that makes noise when the front of the train passes it.
None of this is correct. I have no idea why you would believe any of it.
Nugatory,
Did you get the train and platform observers' equations switched?
Doesn't the train observer's measure of the sound path length need to be L-vT because the train is moving, shortening the distance between the origin of the sound in the still air and the moving observer's interception of that sound... he's closing the gap while the sound is in transit, so the length he wants to time is not the length of the train, but the length of sound travel through still air from origin to interception?
For the platform observer, won't he use the simple L/T calculation because the origin of the sound in the still air remains fixed, as does himself the platform observer... no gap is being closed between the origin of the sound and the intercrption of it, the distance between the origin of the sound and the platform observer remains constant during the transit of the sound; it does not matter what the motion of the train might be after it emits the sound?
Doppler effects will make the sound have different measured frequencies, but the sound speed itself should measure the same value for each observer, right?
DaleSpam,
I'm shocked! All of that paragraph seems to be correct to me... I have no idea why you would not believe any of it... I must have some grave misunderstanding; could you elaborate on what's incorrect?
bahamagreen said:
Nugatory,
No.
The train observer records sound being emitted at the front of the train at time zero and detected at the back end of the train at time ##T##. As far as he's concerned he's at rest while the air and platform are moving backwards, so for him the distance between those two points is ##L## and the speed of travel is ##L/T##.
The platform observer sees the sound emitted at time zero. Call the position of the front of the train at that time position zero, and then the back of the train is at position ##-L## at time zero. But when the sound reaches the back of the train at time ##T##, the back of the train has moved to position ##-L+vT##, so the distance between the point of emission and point of detection is ##L-vT##.
It's worth noting that ##L-vT## is the speed of sound in still air in this thought experiment; the still-air frame is the one in which is ##v## is zero.
I'm providing a long response to help identify the problem or misunderstanding... I'm continuing to think the calculations are switched...?
"As far as he's concerned he's at rest while the air and platform are moving backwards..."
But, if what he wants to measure the air speed of sound through the air (as in with respect to the air, meaning how fast the sound moves through the air from the "at rest" perspective of the air itself), then the train observer does not want to measure the length of the train and use that as L, he wants to measure the still air distance through which the sound travels between origin and interception. That still air distance is shorter than the length of the train moving through the air. This is the very same argument to present for the platform observer's calculation.
Either that, or he needs to take the apparent wind speed velocity into account and adjust the time measure longer...
He wants to measure the speed of sound through air itself, through air at rest... it seems he must take either the closing travel length gap or the additional wind speed into account to measure speed of sound. If he does not do the adjustment, his measurement is confounded and is not m/s wrt air at rest.
You are not suggesting that "air speed of sound" measurements mean anything taken from moving windy conditions without compensating those factors? Air speed of sound always means speed of sound with respect to still air, the air itself, right?
If the train were not moving and there was a steady wind, the observer would adjust for the wind speed when calculating and reporting "the airspeed of sound"... on the moving train, or on a stationary train on a windy day, if he just uses L/T I don't think you can say that he is measuring sound speed. He is measuring elapsed time and the wrong distance, but not the air speed of sound.
I'm not following your explanation of the platform observer's measurement... why is he looking for the sound to reach the back of the train? He is measuring from the emission at the front of the train along the direct path to his own location... that distance is fixed, so he takes that distance "L" (not the train length), and divides by his own measure of "T". The motion of the train, the length of the train, and anything happening at the back of the train are all irrelevant to him. Neither the point of emission of the sound, nor the point where he intercepts the sound on the platform are moving, no gap is closing, and no wind is blowing... it is a direct measure of the air speed of sound between the place where it starts at the front of the train (even the train itself is irrelevant, could have just been a horn set stationary on the tracks) and his stationary position on the platform.
Your argument:
The platform observer sees the sound emitted at time zero. Call the position of the front of the train at that time position zero, and then the back of the train is at position −L at time zero. But when the sound reaches the back of
the train at time T, the back of the train has moved to position
−L+vT, so the distance between the point of
emission and point of detection is L−vT.
actually applies to the train observer... that is why I think you might have the calculations switched between the observers... this is not a Relativity problem... the frame of reference for both observers is the frame within which the still air is at rest, which corresponds to that of the ground, and the platform, and with respect to which both observers will base their calculations of the air speed of sound through that frame.
Well for instance p=hc/λ does not apply to the momentum of air particles in a sound wave.
Just use your good sense -
- the speed of sound is not invarient so anything that relies on invarience will not work.
(...the doppler shift equations are different for light for eg.)
- light is a transverse wave with magnetic and electric vectors, by comparison sound waves are logitudinal in only one vector (displacement).
- and so on.
Light and sound are inherently different phenomenon - you cannot just blindly substitute equations just because some of the letters are the same.
Yes, of course if he wants the speed of sound relative to the air it is propagating through, then he has to allows for his speed relative to the air. But we should carefully state when we are switching frames - the train observer is MEASURING the speed of sound in his frame in which the air is moving, and then applying the Galilean transforms to CALCULATE the speed of sound in a frame in which the air is at rest.
Your immediate reaction may be to say that I'm quibbling because it's obvious that the "real" speed of sound is the speed of sound in still air, and therefore that the train frame results are bogus and distorted by the air movement. But consider that:
- The ##T## and ##L## values are the only measurement results directly available to the train observer. He has to work with uncorrected speed measurements because that's all he has in his observational data.
- Suppose neither the platform nor the train observers knew up front that air existed and that sound waves propagated through it. Just by comparing their observations of distance traveled and elapsed time in their respective frames, they would be able to advance the hypothesis that there is air, that sound travels at a constant velocity relative to air, that the platform observer is at rest relative to the air, and the train observer is not.
- Consider a different observation in the same thought experiment setup: We look at the damage done by a windblown object striking the observer at the back of a train. It's going to be very hard to persuade the train observer that the quantity ##L/T## is not a physically meaningful and completely real speed; conversely the platform observer will begin analyzing the collision by applying the Galilean transforms to get to the moving-air frame.
bahamagreen said:
DaleSpam,
Sure.
The speed of the sound wave in one reference frame is related to the speed in another frame by the relativistic velocity addition formula. The two speeds are only equal if they are the speed of light, which is the one and only invariant speed.
If the whistle is in the very front of the train then by Doppler the wavelength near the engine observer is the same as the wavelength near the caboose observer, and both are longer than the wavelength would be if the train were at rest. If the whistle is between the engine and caboose observers then the wavelength near the engine observer is shorter and the wavelength near the caboose observer is longer than the at-rest wavelength.
In either case, there is no compression of wavelength near the caboose observer.
Note, the usual Doppler formula assumes that the medium is at rest, so it only applies directly to the ground frame.
The air isn't still in the train frame. It is moving. The train observers will definitely notice a change in the air speed. More importantly for an interferometer, the speed will be anisotropic, indicating the direction of the airflow. That is, after all, the whole point of the measurement.
GerryB said:
The sound wave will have no velocity added to it by the moving source. They will agree on the speed of the sound wave, though their reference frames are in motion relative to one another.
The sound wave will indeed have no velocity added to it by the moving source, but it will have velocity added to it by the moving medium. This applies to sound and also to light moving in something other than vacuum, as was demonstrated in 1851: http://en.wikipedia.org/wiki/Fizeau_experiment
DaleSpam: "The speed of the sound wave in one reference frame is related to the speed in another frame by the relativistic velocity addition formula. The two speeds are only equal if they are the speed of light, which is the one and only invariant speed."
This is not a relativity situation...
With the train speed about 30mph the observers' sound speed measures differ due to evoking relativistic velocity addition on order of 10^(-15)... well inside sub-molecular measurement error noise level.
DaleSpam: "If the whistle is in the very front of the train then by Doppler the wavelength near the engine observer is the same as the wavelength near the caboose observer, and both are longer than the wavelength would be if the train were at rest."
But since both observers are moving through that still air toward the sound source, their interception of a wavelength will occur over a shortened period, so the apparent frequency will be increased to correspond to that mechanical frequency local to the whistle (same pitch as if the train was at a dead stop in still air)..
DaleSpam: "If the whistle is between the engine and caboose observers then the wavelength near the engine observer is shorter and the wavelength near the caboose observer is longer than the at-rest wavelength.
But the forward observer is moving away from the waves, the rear observer toward the waves... the forward observer's motion acts to increase the time duration of the wavelengths' passage, the rear observer's motion acts to shorten the time duration of wavelength passage - this later is the compression to which GerryB refers... the wavelength's still air period is being shortened by the rear observer's movement through the air, just as if he was approaching a fixed sound source; intercepting more wavelength per unit time, shortening the measured wavelength, compressing the wave-train to higher frequency.
"The air isn't still in the train frame. It is moving."
"The sound wave will indeed have no velocity added to it by the moving source, but it will have velocity added to it by the moving medium."
This is not a relativity situation; the air is still, the train is moving, the sound source is moving, the medium is not moving.
Likes 1 person
It certainly is a relativity situation since we are trying to determine what results are like in different frames.
Clearly 30 mph is low enough that you are justified in using Galilean relativity instead of Special Relativity, but either way it is relativity and my answer stands. The speed of sound is not the same in the two frames in Galilean relativity either.
Yes, this is the correct explanation of the received frequency. Not that the wavelength is shortened, but that they pass over the longer wavelength in a shorter time.
Again, you are interested in two frames so it is a relativity situation, but you are perfectly fine using Galilan relativity for this. It doesn't change any of my comments. The air is still in the station and train is moving. The train is still in the train and the air is moving, the speed of sound as measured by an interferometer is anisotropic.
Likes 1 person
You are technically correct - the best kind of correct.
Likes 1 person
The best kind of correct is actually the kind that makes you attractive and rich ;)
Well Simon, we seem to be moving from physics into philosophy. Are you saying that the train observer and the platform observer measure different speeds for the sound wave from the train whistle?
Nugatory said:
...there's a strong wind blowing towards the rear of the train. The platform observer doesn't experience that wind (because it's a "windless day", right?).
Well Nugatory, creating wind on a "windless day" seems to be more of a philosophical problem than a physics problem. A passenger will experience a "breeze" through an open window on a moving train. The wind has been created by the train moving through the air molecules, not the air moving past train. Even by the classical Doppler equations, these are not equivalent scenarios. The air and platform moving to meet a resting train is not philosophically equivalent to the train moving towards the stationary platform.
Nugatory said:
As far as he's concerned he's at rest while the air and platform are moving backwards...is the speed of sound in still air in this thought experiment; the still-air frame is the one in which ...is zero.
Well argued points bahamagreen.
Wind tunnels disprove this every day.
How do I distinguish the two cases? Under what circumstances am I justified in insisting that the train is moving past the air molecules instead of the air molecules moving past the train? Can you describe an experiment that will distinguish between the two cases?
Certainly I am talking about the classical principle of relativity and how that relates to Einstein STR. The 30 mph is certainly a reasonable value for producing results in this experiment
The philosophical problem is, to which reference frame does the still air belong, in an intuitive sense. Can we say that one person can mathematically claim an air molecule is at rest, and another observer claim one and the same molucule is in motion in mathemaical terms. The passenger on the train says there is a "wind" and the commuter at the station says there is no "wind," and they are looking at the same air molecule. Is the still air capable of moving freely through a reference frame, or is it trapped by the invisible walls of a set coordinate axes.
I want to be rich, but I have given up on ever being attractive in this lifetime.
Things don't "belong" to a reference frame. A reference frame is just a convention for using numbers to describe the position of an object at any given moment. We have this air molecule, and you might say that it's two meters east of you while I say it's five meters west of me - it's the exact same air molecule in the exact same place and we're using different reference frames to describe its position. There's no reason why it's more "my" air molecule at position -5 than it is "your" air molecule at position +2.
Can we say that one person can mathematically claim an air molecule is at rest, and another observer claim one and the same molecule is in motion in mathemaical terms.
Yes. Let ##x(t)## be the position of the air molecule at time ##t## using my coordinates. Let ##x'(t)## be the position of the same air molecule at time ##t## using your coordinates. If ##dx/dt## is zero then I will correctly claim that the particle is at rest; if ##dx'/dt## is zero than you will. Depending on the choice of frame, neither, either, or both of these derivatives may be zero.
Let us say that the train and whistle (source) are approaching the stationary platform observer (receiver). The classical Doppler formula which the platform observer would use is:
ƒ = [c / (c + vs)]ƒ0
If the platform and the non-walking observer (as well as the entire earth) were approaching a stationary train and blowing whistle, then the classical Doppler formula would be:
ƒ = [(c + vr) / c]ƒ0
Clearly these two frequency values are different. So the platform observer can distinguish between the platform moving towards the train whistle, versus the train moving towards the platform.
If the caboose observer were to begin sprinting along the roof of the train towards the whistle, she could use the same formulas to distinguish whether the train is moving through the still air molecules, or a wind is blowing past a stationary train.
An interesting effect was predicted by Lord Rayleigh in his classic book on sound: if the source is moving at twice the speed of sound, a musical piece emitted by that source would be heard in correct time and tune, but backwards.[6]
http://en.wikipedia.org/wiki/Doppler_effect
  • #31
We don't generally do philosophy here. There is no theoretical or experimental sense in which an object belongs to a particular reference frame. Any philosophical problems are tangential to the physics.
Yes, that is exactly what the principle of relativity implies, not just in mathematical terms, but in terms of the laws of physics.
  • #32
No, this would be the formula if the train and whistle were moving *away* from the platform observer. If they are moving *toward* the platform observer, the formula is
ƒ = [(c + vs) / c]ƒ0
Which is the same as the formula for the case of a stationary train and whistle and a moving observer, since vs = vr.
  • #33
The velocity in the classical Doppler is the velocity wrt the medium. You can distinguish between source moving wrt the medium and receiver moving wrt the medium according to the classical formula. However, you cannot distinguish between a moving and a stationary medium even classically.
  • #34
No.
The quoted passage makes two assertions:
1. the doppler shift is different for moving but stationary observer vs moving observer stationary source. The actual equations are different in galilean relativity - which is what you want to use.
2. the speed of sound in a medium is not invarient like the speed of light in a vacuum is.
Nope - it is a well known and tested physical phenomenon - to make wind on a windless day you just have to have some speed wrt the air.
Try this yourself - drive in a car with the window down. Notice the wind?
Makes no difference to the physics - these two situations are physically identical from the POV of the passenger.
Can you provide an experiment that the Newtonian equivalence principle does not hold in these two circumstances?
We can demonstrate that galilean relativity does not hold at high speeds though - which is why we need to modify the doppler effect equation for special relativity.
  • #35
In any science text I have read on the classical Doppler effect, there is one set of formulas for the source approachig the receiver, or moving away from the receiver. There is another set of formulas for the receiver approaching the source, or moving away from the source. And they are noticably different.
  • #37
As my buddy once said while drinking some beers at a local bar, "Mathematics is not Reality."
The galilean transformation offers up two different values for one and the same particle (velocity, position, etc.) Which value is the truth, which is the REAL value?
  • #38
The formulas for approaching vs. moving away should certainly be noticeably different, yes. For approaching, the observed frequency at the receiver should be higher than the emitted frequency at the source; but for moving away, the observed frequency should be lower. The formula you wrote down for the moving source case (the one with vs) says the opposite.
But the formulas for source moving vs. receiver moving should be the same once you specify approaching or moving away. That's a simple consequence of the principle of relativity, and classical physics obeys the principle of relativity. Classical physics uses Galilean transformations instead of Lorentz transformations to mathematically realize the principle of relativity, but for speeds much less than the speed of light the two are the same.
I suspect that you have misread whatever reference you used. Can you give a specific reference that you are interpreting the way you describe?
  • #39
Certainly these formulas are with respect to the medium. On a windless day, the medium is connected to the stationary observer, which is connected to the stationary earth. So if the medium is moving towrds the source, then the platform and the Earth are also moving towards the stationary source, at the same velocity. So the receiver will use one set of formulas.
Again on a windless day, if the train is moving with a certain velocity relative to the medium, then the train is also moving at the same velocity with respect to the platform and the earth. This requires a different set of Doppler formulas.
The classical Doppler formulas do account for the scenario you have described.
DaleSpam said:
Here is a good source on Doppler, which presents the acoustic and light in a reasonably well unified framework.
http://www.mathpages.com/rr/s2-04/2-04.htm
This is an excellent link. It shows the usage of c as the symbol for sound. It also shows how the STR Doppler is negligible at the slow speeds of a train as compared to light.
  • #40
Well Peterdonis, I first read this in Tipler Physics, but I have seen it in many other places as well, as I mentioned above:
http://en.wikipedia.org/wiki/Doppler_effect[/QUOTE]
  • #41
Yes, they do account for the scenario, and they do not support the idea that the speed of sound is frame invariant. Do you understand that now?
No it doesn't. It never once shows that. It is very consistent in using ##c_s## for the speed of a signal and c for the invariant speed.
  • #42
Ah, sorry, I was misinterpreting ##v_r## and ##v_s## as relative velocities of the source and receiver, instead of velocities relative to the medium.
I agree with DaleSpam's responses to you, though. The mathpages article he linked to makes clear the distinction between the speed of propagation of sound (or any other signal) in a medium (##c_s##) and the invariant speed dictated by relativistic kinematics (##c##).
  • #43
There is no single true value. Go back to the example I proposed earlier, where an air molecule is two meters east of you and five meters west of me. Both "two meters east" and "five meters west" are accurate and true statements about its position, but they are not frame-invariant. Indeed, it is because they are frame-dependent that they can both be true; allow me to move around enough and I an make the statement "The air molecule is X meters from me" true for any value of X.
Compare those statements with the equivalent frame-independent invariant statement "The distance between us is seven meters and the air molecule is five/seventh of the way from me to you". That statement is true in all frames and for all observers, and if you change either of the numbers it will be false in all frames for observers - so that's a reasonable candidate for what you're calling a REAL truth.
Of course that's just position, not velocity. But again, there are frame-dependent and frame-independent ways of describing a velocity problem. We can say "You are approaching me from the north at ten meters per second", or we can say "I am approaching you from the south at ten meters per second"; they both can be true because they're both frame-dependent so if we look long enough we'll find some frame in which one of them is true. Again, however, there's an equivalent frame-independent statement that is true for all observers: "The distance between us is shrinking by ten meters per second".
  • #44
Now we have come back around to my original question. What properties do sound waves and light waves share such that scientists use the symbol c to represent the wave velocity of both?
  • #45
The symbol j is used for the imaginary number and current density. The symbol ##\Omega## is used both for electrical resistance and the spatial part of a metric. The symbol f is used for both frequency and function. The symbol x is used for space and for an arbitrary unknown quantity. The symbol ##\phi## is used for potentials and for phase angles. And so forth.
Sound and light are both waves, so they share many substantive similarities (propagation, reflection, refraction, diffraction, energy, phase, frequency, amplitude, etc.). The use of the same symbol is not substantive, it is mere trivia or semantics.
Can you phrase your question in terms of physics, or are you actually interested in such trivia/semantics as the symbols used.
  • #46
I do science, and I write poetry, so words are very important to me. In the examples you mentioned, certainly different branches of science or mathematics may, by happenstance, use the same symbol to describe very different properties. But in physics I would expect that there are some very specific reasons that physicists have chosen certain terminologies to communicate with other physicists.
  • #47
Sometimes there is, but often there is not. For instance color charge or the names of the quark and its flavors. Regardless of the reasons for the choice of a symbol, it is semantics, not physics. Experimental results don't care what symbols we use nor why we use them. "A rose by any other name..."
If you change your mind and decide later that you would like to have a conversation about propagation and interference in sound and light waves, then I would be glad to participate.
  • #48
Nope, it's purely historical accident. "P" for momentum probably comes from the Latin "petere", for example.
When you're writing down your ideas for others to read, it's advantageous to use whatever convention will be most familiar to the largest number of your potential readers, so once a convention is established it tends to become dominant.
  • #49
The ink on paper, the symbols, may not be important, but the meanings behind those symbols is of life and death importance. If the service engine light comes on in your car, the little light cannot harm you, but if you disregard the warning, you will have to suffer the consequence of having to pay for an engine that catches fire because it has no oil in it.
We as scientists must strive to agree on the meanings of the words and symbols we use to communicate with each other, how ever they may have started. If we do not make this agreement, then civilization will cease to exist.
  • #50
So we agree. Then please ask your question in terms of the meanings rather than the symbols. So far, it seems as though you are asking about the ink on paper rather than the physics.
