Cahnge in potential difference of moving electron
An electron moving from a speed of 2.2e^6 m/s to 6.0e^6 m/s experiences an increase in kinetic energy, indicating it moves to a higher electric potential. The relevant equations for solving the potential difference include kinetic energy (K = 1/2mv^2) and the relationship between kinetic energy and potential energy (ΔK = -ΔU). The potential difference can be calculated using ΔV = ΔU/e, where e is the charge of the electron. The discussion clarifies that potential difference and electric potential are distinct concepts, with ΔV specifically referring to the difference in potential. Ultimately, the problem is resolved by applying the correct equations without needing distance or time variables.
Kastner86
As an electron moves through a region of space, its speed increases from 2.2e^6 m/s to 6.0e^6 m/s. The electric force is the only force acting on the electron.
a) Did the electron move to a higher potential or a lower potential?
b)Across what potential difference did the electron travel?
well for part b, I'm not even sure what to use.
K = 1/2mv^2
U=q x V
Well i know part a), the electron moves to a higher potential.
I really don't know how to solve this since the distance or time is not given. And I may be confused as to the difference between potential difference and electric potential. I don't know where to start!
a) Electron moves in the apposite direction to the electric field. In the electric field the potential decreases along its direction. Then...?
b) The electron accelerates when it moves through lower potential to the higher potential. Hence its kinetic energy increases. Use the relevant equations and find the potential difference.
Yes, i understand the electron is accelerating. obviously, its speed increases, so its kinetic energy also increases. I understand all these concepts.
I don't know which equations to use. That is where I'm stuck. All the equations I can think of using velocity have time or distance variable, which i can't use.
The only one I know is K = 1/2mv^2
So would I do \DeltaK = 1/2mv2^2 - 1/2mv1^2
and since \DeltaK = - \DeltaUE
I can then use \DeltaV = \DeltaU/e to get the potential difference?
Is \DeltaV potential difference or just potential or electric potential?? that is one area I am confused.
Thank you
Yes. ΔV = ΔU/e. No area is involved.
This worked!
A big thanks to you. Sometimes just trying to explain the problem to someone else helps me solve it anyways.
Thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
