Calc based physics thermodynamics
The integral of W = -∫Pdv depends on the specific process path, such as isobaric, isochoric, isothermal, or isentropic. For a constant pressure process, the boundary work simplifies to W_b = P(V_2 - V_1). To perform the integration, pressure must be expressed as a function of volume, which can be derived from the ideal gas law. Understanding the type of thermodynamic process is crucial for accurately calculating work done. Properly defining the relationship between pressure and volume is essential for solving these integrals in thermodynamics.
lukasz08
hi. i was wondering on how to do this integral. W= - integral Pdv. what is the integral of dv ?
Science news on Phys.org
It depends on the process path. If you assume it is a constant pressure process, then the boundary work is just W_b = P(V_2 - V_1).
CS
You integrate the pressure with respect to volume. Depending on the process (isobaric, isochoric, isothermal, isentropic) this function (p = f(v)) will be different. These functions can be derived using the ideal gas law.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
