Calcium in Anhydrous Calcium Chloride
  • Thread starter Thread starter Fishworks
    Calcium
The discussion centers around the calcium content percentage in anhydrous calcium chloride, with participants noting the difficulty in finding this information online. One contributor mentions that calculating the percentage from molar masses is straightforward, implying that the lack of readily available data is not surprising. The conversation then shifts to the compatibility of calcium chloride with non-polar solvents, particularly vegetable oil, for use in a solar boiler. It is highlighted that ionic compounds like calcium chloride dissolve well in polar solvents, such as water, while non-polar solvents do not mix effectively with ionic compounds. The rationale behind using a non-polar solvent for vaporization in a solar boiler is questioned, emphasizing the challenges of mixing polar and non-polar substances.
Fishworks
Hi All,
Does anyone know the Calcium Content Percentage% in Calcium Chloride Anhydrous?
I have tried google searching with no results.
Chemistry news on Phys.org
None? Really?
Bystander said:
None? Really?
None, the best I could get was for CaCl2.2H2O :frown:
Don't get me wrong, not trying to be a smartass here, but it is so trivial to calculate from molar masses I am not surprised it is not listed as something special. It is a bit like saying "googled, but couldn't find information about how much is 40/(40+2*35.5)*100%" :wink:
Likes symbolipoint, BillTre and Bystander
Other than water, does exist any non water fluid i could use as solvent for it?
I would like to use some sort of vegetable oil since it doesn't mix with Water but to make it able to hold small droplets of it in suspension, then to vaporize them in the solar boiler outside..
it could be biodiesel, vegetable bases hydraulic fluid, i don't know..
I'm asking this because i'm not a chemistrian, i'm involved non professionaly with computers , electronics, robotics, etc etc.
In general, ionic compounds readily dissolve in polar solvents, the more polar the better.
Water is a polar solvent, vegetable oil is not polar.
Polar and non-polar solvents don't mix well either.
Why would you want to add something to a solvent then vaporize it (solvent or solute) in a solar boiler?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
