Calculate [Ag+] in Test Solution with Nernst Eq. (Chem 102 Lab)
  • Thread starter Thread starter loadsy
    Chem Lab
The discussion focuses on calculating the concentration of silver ions ([Ag+]) in a test solution using the Nernst equation based on a measured cell potential of 0.280V. The relevant reaction is Ag2CO3(s) <-> 2Ag+(aq) + CO3^2-(aq), with the Nernst equation given as Ecell = E^0cell - 0.05916V/n logQcell. An initial calculation incorrectly assumed n=1 for electron transfer, but it was clarified that n should be 2, leading to a revised understanding of the calculation process. The standard cell potentials for the cathode and anode were discussed, confirming that the values from the chemistry data sheet were likely correct. The conversation emphasizes the importance of accurate electron transfer numbers and standard potentials in applying the Nernst equation correctly.
loadsy
The question asks: Using the measured cell potential and the Nernst equation, calculate the [Ag+] in the test solution. However, you guys will need a little bit of background information to answer this question since it is a lab. First of all this reaction was:
Ag2CO3(s) <-> 2Ag+(aq) +CO3^2-(aq)
Also the Nernst equation we are using is the following:
Ecell = E^0cell -0.05916V/n logQcell
And, the Ecell potential that I calculated was 0.280V
2. The attempt at a solution
So I've made an attempt at this question, but I'm not too positive if I'm solving it correctly. From the reaction we know that n=1 (1 electron being transferred between the reactants and products). Therefore:
0.280V = 0.800V-0.468V(Standard potentials off CDS)- 0.05916V/1 log[Ag+]^2
0.280V = 0.332V-0.5916V log[Ag+]^2
1.026 = log[Ag+]^2
1.013 = log[Ag+]
[Ag+] 0.00562 = 5.63X10^-3 mol/L
However, I'm not too positive if this is correct or if I should be looking in the Chemistry Data Sheet for the standard potentials of the cathode and anode. Thanks for any help guys. :D
Actually, here n will be 2 since the total number of electrons traded is 2. Your calculation looks wrong. If 1.013=log[Ag+], then [Ag+] should be 10^{1.013} which should be greater than 10, not smaller.
Ahhh okay, yeah I'm not sure why I said 1, it clearly is n=2 for the number of electrons being traded. That makes a bit more sense. Thank you for your help.
My only other question is whether or not I got the standard cell potentials right from the chemistry data sheet. Because I know that the cathode is Ag in this case, so looking on the CDS, we find it is 0.800V and then the anode I said was from the equation Ag2CO3(s) + 2e^- -> 2Ag(s) + CO3^2- which is 0.468. I'm assuming those are correct for this case, and that it's just an error in my calculation. Thanks again though.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
