MHB Calculate Area of Triangle ABC
  • Thread starter Thread starter mathdad
    Area Triangle
The discussion focuses on calculating the area of Triangle ABC formed by points A(3, 4), B(8, 5), and C(7, 8) using a specific formula. The formula provided appears to have some typos, and an alternative method for calculating the area is suggested, which involves a different expression derived from the coordinates. Participants agree that the problem is straightforward, emphasizing a plug-and-chug approach to find the area. The conversation highlights the importance of correctly applying the formula and ensuring all variables are accurately represented. Overall, the area calculation process is clarified, with attention drawn to potential errors in the original formula.
mathdad
Point A(3, 4), point B(8, 5) and point C(7, 8) are located in quadrant 1 and form Triangle ABC.
Note:
Point A(a, b)
Point B(c, d)
Point C(e, f)
Find the area of Triangle ABC using the formula below.
A = (1/2)(a*d - c*b + c*e - e*d + e*b - a*e)
I think this is just a plug and chug problem. It looks tricky but in reality, it's not that bad.
I see it this way:
a = 3
b = 4
c = 8
d = 5
e = 7
f = 8
I plug the values of a through e (not including f) into the formula to calculate the area of Triangle ABC. Am I right?
Mathematics news on Phys.org
As you can find derived here:
http://mathhelpboards.com/math-notes-49/finding-area-triangle-formed-3-points-plane-2954.html
we have:
$$A=\frac{1}{2}\left|(x_3-x_1)(y_2-y_1)-(x_2-x_1)(y_3-y_1) \right|$$
and putting this in terms of the given coordinates, we have:
$$A=\frac{1}{2}\left|(e-a)(d-b)-(c-a)(f-b) \right|$$
$$A=\frac{1}{2}\left|-ad+af+bc-be-cf+de \right|$$
Change the signs to match your formula:
$$A=\frac{1}{2}\left|ad-af-bc+be+cf-de \right|$$
Thus, I would posit that the formula you have been given has a few typos in it. :D
we have:
I made a few typos. Thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
