MHB Calculate Capitalised Cost for Perpetual Service in PrivaPower Ltd
  • Thread starter Thread starter waptrick
PrivaPower Ltd is calculating the capitalized cost for a hydro-electric power station, focusing on the perpetual service costs associated with turbine maintenance and replacement. The initial installation cost of the turbines is R5,000,000, with a lifespan of 25 years, requiring replacement at the same cost. Annual maintenance starts at R100,000, increasing by 4% each year, while the initial maintenance cost is R50,000, rising by 11% annually. The calculated capitalized cost for the annual maintenance amounts to approximately R27,127,530. The final present value of the maintenance costs, adjusted for the cost of capital at 14%, is estimated at R553,343.65.
waptrick
PrivaPower Ltd is considering the construction
of a hydro-electric power station. The
electricity generated by the power station
will be sold to Eskom. You are required to
calculate the capitalised cost now of the
perpetual service if the enterprise’s cost of
capital amounts to 14% per annum. The
following information is provided to you:
After completion of the dam wall’s construction
(i.e. five years from now) the turbines can be
installed. The cost associated with this will amount
to R5 000 000. The turbines’ expected lifetime is 25
years, where afterit must be replaced. It is expected
that the replacement will take place every 25
years at the same cost of R5 000 000 per occasion.
My question is:
Suppose, however, that it is indicated that the annual maintenance cost (payable at the beginning of each year) of the turbines will amount to R50 000 when the first turbines are installed, and that this annual cost will thereafter increase by 11% per year (each year in comparison to the immediately preceding year) as a result of inflation. Recalculate the capitalised cost of the annual maintenance cost.
Mathematics news on Phys.org
After the installation of the turbines took place,
annual maintenance will be required. The annual
maintenance cost of the turbines amounts to
R100 000 per year (payable at the beginning of
the first year that the turbines are used). As a
result of the wear-and-tear of the turbines,
however, it is expected that the maintenance cost
will increase by 4% per year thereafter (each year
in comparison to the immediately preceding year).
That is the original question regarding the capitalized cost for the annual maintenance cost.
I calculated this by:
100000(1+0.14)(((1.14)^25-(1.11)^25)/0.14-0.11)= 27127530.61
then using my financial calculator
FV= 27127530.61
N= 25
I/YR= 14
PMT=?
therefore pmt= 149158.229624
PV5= 149158.229624/0.14= 1065415.92589
PV0= 1065415.92589/1.14^5= 553343.65
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 18 ·
