Calculate Change in Energy for n=4 to n=1 Hydrogen Atom
  • Thread starter Thread starter xmflea
    Chem
The change in energy for the transition from n=4 to n=1 in a hydrogen atom is calculated using the formula E = -Rh(1/n(low)^2 - 1/n(high)^2). The correct answer for this transition is -2.04E-18J, indicating that energy is released when the electron moves to a lower energy level. Confusion arises from differing interpretations of the sign of the energy change, with some sources suggesting it could be positive. However, the negative sign reflects that energy is lost by the atom and gained by the surroundings. Ultimately, the sign of the change in energy depends on the perspective of the system versus its environment.
xmflea
Calculate the change in energy when the following transition occurs in the hydrogen atom.
n = 4 ----> n = 1
equation
E = -Rh/n^2
eventually my answer is 2.04E-18J because my book tells me to take 1 over n(low) squared minus 1over n(high) squared and multiply by rydberg constant.. so doing it according to the book i get a positive number
but the answer is -2.04E-18J... and now after looking online... I am getting serveral mixed sources, some saying that it is positive, others saying it is negative.. which is it.
Negative.
This is change in energy. Whatever atom loses is gained by surroundings, so sign if the change is either negative or positive, depending on the point of view.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
