Calculate Electron Flow in 3 Secs
  • Thread starter Thread starter mp252
    Charge Electron
To calculate the number of electrons leaving the battery's negative terminal in 3 seconds with a current of 2 A, first recognize that 1 Ampere equals 1 Coulomb per second. Therefore, in 3 seconds, the total charge is 2 A x 3 s = 6 Coulombs. Given that the charge of a single electron is approximately 1.602 x 10^-19 C, the number of electrons can be calculated by dividing the total charge by the charge of one electron. This results in approximately 3.75 x 10^19 electrons leaving the battery in that time frame. Understanding these principles is crucial for accurately calculating electron flow in electrical circuits.
mp252
i was stuck on this equation if a current of 2 A flows through a lamp when it is connected by copper wire of cross-sectional area 1 mm2 to the terminals of a battery. how many electrons will leave the negative terminal of the battery in 3 seconds? (obiviously the charge of electrons is e=1.602*10–19 C.
What is the definition of an ampere in terms of coulombs and seconds?
1a=1c/1s
mp252 said:
1a=1c/1s
Right. An Ampere is one Coulomb of charge per second. How many electrons make up one Coulomb?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
