Calculate Isentropic Efficiency: Tips & Tricks
To calculate the isentropic efficiency of an expander in an Organic Rankine Cycle (ORC) using experimental inlet and outlet data, one must first determine the isentropic enthalpy using the entropy values. The actual enthalpy at the expander exit can be found using steam tables, but this requires knowing the quality or dryness fraction if the exit conditions are in the two-phase zone. If the quality is unknown, it complicates the calculation of efficiency. The isentropic efficiency can be calculated with the formula: η_isent = (H_in - H_out) / (H_in - H_isent). Accurate determination of enthalpy is crucial for obtaining the correct efficiency value.
y2j
Hi
can anyone help me about the following ?
if I have the experimental data of inlet and outlet of expander (temperature and pressure) working in ORC.
Now if I want to find the Isentropic efficiencie :
the Isentropic expansion can be found by (entropy in = entropy out)
but how to find the actual enthalpy at expander exit of actual expansion
(i.e. I can consider it in the mixture or superheated phase?)
thank you
entropy in = entropy out gives you an enthalpy. Enthalpy difference * efficiency gives you a new enthalpy. Pressure and enthalpy give you a temperature (or a composition at saturation).
See e.g. here ( I Googled "isentropic efficiency turbine" and looked at the first image)
Likes y2j
thanks for reply
but i am not have the Isentropic Efficiency
I am only have pressure and temperature of experimental system and I would like to have the Isentropic Efficiency if the exit conditions locate in tow phase zone
Then you work backwards from the enthalpy observed...
Likes y2j
I don't understated you
what do you mean?
thanks again
Perhaps you should post your work so far.
You have enthalpy in ##H_{in}##
entropy in = entropy out gives you an enthalpy under isentropic conditions ##H_{isent}##
observed enthalpy ##H_{out}##
$$\eta_{isent} = {H_{in} - H_{out}\over H_{in} - H_{isent}}$$
Likes y2j and gracy
I am not have the Isentropic Efficiency
I am only have pressures and temperatures at inlet and outlet of the
turbine
how can obtain Isentropic Efficiency in this case
thanks for attention
Is it clear now ?
not yet
Writing the same text in red does not help me to understand where you have a problem. Can you post your work so far ?
Likes y2j
OK
I have an experimental data of inlet and outlet conditions of turbine (temperature and pressure ) working in a rankine cycle
when the exit condition from turbine in saturated phase
how I can find the actual enthalpy at exit (##H_{out}##)and that used to find the Isentropic Efficiency
No need to get desperate...
Enthalpies can be looked up in a steam table. Do you have that available in some form or other ?
Likes y2j
Enthalpies in the mixture zone given for vapor and liquid
in this case to find Enthalpy we must have another parameter is (quality x) or dryness fraction
and the later I have not
I agree. That makes it difficult to get the correct value of ##\eta##. All I can imagine is that you assume no water comes out of the tubine, only steam...
