Calculate most probable energy from Maxwell-Boltzmann distribution of energy
  • Thread starter Thread starter TehDarkArchon
    Distribution Energy
The discussion focuses on calculating the most probable energy from the Maxwell-Boltzmann distribution of energy, specifically the function f(E)=2*pi*E^(1/2)*(1/pi*k*T)^(3/2)*e^(-E/kT). Participants clarify that the problem requires finding the maximum of f(E) rather than integrating it, which is a common misconception. The correct approach involves setting the derivative of f(E) to zero to find the maximum point, leading to the conclusion that the most probable energy is kt/2. The conversation emphasizes understanding the distinction between average and most probable values in statistical mechanics. Ultimately, the participants successfully derive the answer with collaborative assistance.
TehDarkArchon
If the Maxwell-Boltzmann distribution of energy is f(E)=2*pi*E1/2*(1/pi*k*T)3/2*eE/kT. Can you calculate the most probable energy from this? (The answer is kt/2).
Some kind of integration (guassian integral) is needed from 0 to infinity I believe.
I tried integration by parts and some other methods with no luck. My teacher made it clear that this is not a gamma function (my initial thought since the E1/2 is paired with an exponential function) and that the answer is relatively easy. Any help would be much appreciated!
Wikipedia says that it is a gamma distribution...
Also, shouldn't it be e-E/kT?
It is supposed to be e^-E/kT, sorry about that. Unfortunately he made it clear that it's not a gamma function...and integration by parts only causes that term to be 1/2(E)^1/2 and just ends up being more complicated. We have discussed transformation of variables and guassian integrals in class, so perhaps that's the way to go about this problem (I'm still getting used to both of these as I've never done them before this class, thus probably why I'm struggling so much.)
You don't need to integrate at all. You're thinking of the average value, or expectation value, of energy. The problem is asking for the most probable energy.
Okay that makes sense...I was going off my teacher's example of how to calculate most probable velocity from the Maxwell-Boltzmann distribution. Any hint on what kind of calculation I need to do to get most probable energy? I'm probably going to feel incredibly stupid once I figure it out...
What does the phrase "most probable" translate to mathematically in terms of f(E)?
Think about the curve of f(E) against E.
f(E) is just a function of E, with the most probable energy being the energy that most of the molecules have in the system, so should I just compute the value to infinity?
No. What does f(E) represent?
I know we already have some people helping but, think "optimization problems"...
Yep, jfy4 has the right idea.
Another hint: If you had the graph of f(E) against E, you could simply see by looking at it what the most probable energy was.
Ahh I think I see how to get it now. Basically Emp is the maximum of f(E) so you'd go about this problem how you would any graph to find the maximum, by setting the derivative to 0. By setting all of the constants equal to Q, canceling Q and the exponential function on both sides, i made \frac{1}{2\sqrt{E}} = \frac{\sqrt{E}}{kT}. With some rearrangement I get kT = 2E, or kt/2 = E.
well done.
Thanks very much everyone for your help! I appreciate it so much!
  • · Replies 17 ·
  • · Replies 0 ·
