Calculate Ratio of Masses A & B After Collision
  • Thread starter Thread starter Gloyn
    Collision
The discussion focuses on calculating the ratio of masses A and B after an elastic collision, where mass A is initially moving towards stationary mass B. The key equations involved are the conservation of momentum and energy, which are applied to derive the mass ratio based on the angle β between the final velocities of the two masses. Participants clarify that the angle β is specified as 60 degrees, leading to the realization that the equations must be adjusted to reflect this angle correctly. The conversation emphasizes that while there are three equations and four variables, they can still determine the mass ratio by expressing the equations in terms of the mass ratio and the velocities. Ultimately, the correct interpretation and manipulation of the equations allow for the calculation of the mass ratio, which is found to be 2.
Gloyn
Mass A is moving towards mass B, which is stationary. Collision is elastic. After the collision both masses are mobing symmetrically to the initial direction of motion of mass A.
What is the ratio of masses A and B if the angle between directions of motion of the masses is β?
Principle of conservation of momentum:
-along the initial direction of A
m_1v_1=m_1u_1cosβ+m_2u_2cosβ
-along the direction perpendicular to the one mentioned above
m_1u_1sinβ=m_2u_2sinβ
Principle of conservationj of energy:
m_1v_1^2=m_1u_1^2+m_2u_2^2
Does the 'symmetrical motion' mean that u_1=u_2? If so, then m1=m2, but the answer for this question is m1/m2=2.
Hello, I think that they are moving like I sketched. You said mobing symmetrically to the initial direction of motion.
Hello, Gloyn.
I interpret the wording as saying that β is the angle between the u1 and u2 directions. Also, I interpret "moving symmetrically to the initial direction of A" as meaning that u1 and u2 make the same angle with respect to the initial direction of motion of A.
As you say, if you also require u1 = u2 then the ratio of masses would have to be 1. So, I would assume that u1 ≠ u2. But then, I would think that the answer for the ratio of the masses would depend on β. Did they specify a value of β?
Yes, they did. So they're not in symmetricall positions in every moment, but paths are symmetrical, right? What can we do about it then? Those three equations i mentioned are not enough, i guess?
Gloyn said:
Yes, they did.
Are you saying they did specify a value for β? If so, what value was given?
So they're not in symmetrical positions in every moment, but paths are symmetrical, right? What can we do about it then? Those three equations i mentioned are not enough, i guess?
That's how I would interpret the problem. When I work out the ratio of the masses I get a result that depends on β.
Oh, betha is 60 degrees. Can I see how did you work out the formula for the ratio?
Ok, I get the correct answer for β = 60o.
Note that β is given to be the angle between the two final velocities. So, what angle should be in your equations? Your equations all look good, by the way, except you should not be using β as the angle. Instead you should use an angle related to β.
Oh, yeah, it should be 30 degrees, so half betha. But I only have 3 equations and 4 variables (ratio and 3 different velocities). How do I overcome this?
You only care about the ratio of the masses, so it will turn out that your 3 equations are enough.
The equations cannot determine values for all 4 quantities. But you can think of the three equations as equations for three unknowns: the ratio of the masses, the ratio u1/v1, and the ratio u2/v1. You can see that if you divided all three equations by m2, the first two equations by v1 and the last equation by v12, you would get three equations for the 3 unknown ratios. [Edited]
You are looking for the ratio of m1/m2, which you can just call r. Can you express each equation in terms of r? What does the 2nd equation give you for u2 in terms of u1 and r?
Oh, I'm dumb. Thank you guys.
