Calculate Resonant Frequency & Capacitive Reactance
  • Thread starter Thread starter aurao2003
    Reactance
To calculate the resonant frequency of a circuit with a 300uF capacitor and an 800mH inductor, the formula f = 1/2π(LC)^(1/2) is used, yielding a frequency of approximately 10.3 Hz. The capacitive reactance (Xc) is calculated using Xc = -1/2πfC, confirming that it should be expressed as a negative value in ohms. Participants emphasize the importance of including appropriate units in calculations. The overall consensus is that the calculations appear correct, and the negative sign for capacitive reactance is standard practice. Accurate presentation of the final answers is crucial for academic success.
aurao2003
Now demonstrate how to calculate resonant frequency. Calculate the capacitive reactance for a 300uF capacitor in series with a 800mH inductor.
f = 1/2pi(LC)^1/2
Xc = -1/2pifC
Hi
I urgently need this solution checked out for my BTech deadline. The question reads thus:
where L = 800mH, C = 300uF
so,
f = 1/2pi(800 x 10^-3 x 300 x 10^-6)
So, f = 10.3 Hz
so, Xc =-1/2pi (10.27 x 300 x 10^-6)
Will my final answer be expressed as a negative?
Any suggestions will be appreciated.
Thanks a lot in advance.
f = 1/2pi(LC)^1/2
Xc = -1/2pifC
Hi
so,
So, f = 10.3 Hz
Technically capacitive reactance is a negative reactance, so best to express it so. Also be sure to assign it the appropriate units! Everything should have units :wink:
So, my final answer is in ohms and negative. Aside from that, is my working okay? I feel its fine but its the determinant for a distinction or a merit.
Thanks.
Harold251 said:
be sure to assign it the appropriate unitshttp://www.infoocean.info/avatar2.jpg
Thanks everyone. I take that as a yes! My sincere appreciation and gratitude.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
