Calculate scattering amplitude by delta function potential
The discussion focuses on calculating the scattering amplitude f(θ) using the Born approximation for a delta function potential δ(r) in spherical coordinates. The main equation for scattering amplitude involves an integral that presents challenges when incorporating the delta function, particularly due to the integration starting at zero. Participants suggest considering the delta function as three-dimensional and recommend using the identity for integrating over volume to resolve the issue. There is also a side conversation about using LaTeX for formatting mathematical expressions. The thread emphasizes the need to correctly apply the delta function to obtain a valid scattering amplitude.
liumylife
I need to give scattering amplitude f(θ) in Born approximation to the first order in the case of delta function scattering potential δ(r). The problem is in spherical coordinate and I'll give major equation concerned.
The equation for scattering amplitude is given by
f(θ) = C ∫_0^∞ dr rV(r)sinqr
where q is only a function of θ, so treat it as a constant in this formula, and C is just another constant, too.
The only issue left is to insert the delta function into the formula, and this is exactly the problem: no equation can be used in such case where the integral range begin just at zero.
I look every textbook to find useful formulas, found nothing.
And I tried to create a new function such that the integral range is from -∞ to ∞,
then half the new integral to obtain a result, but it achieved nothing since it gives zero, so help me, please!
Your problem is that x δ(x) is zero everywhere, so the integral vanishes. Are you sure that delta function is one-dimensional? That seems strange. Perhaps it's 3-dimensional instead. Try massaging the identity \int dV \delta^3(r) = 1 to see the magic happen.
that is not the scattering amplitude with any potential,use the three dimensional delta function and calculate the Fourier transform of it to obtain amplitude.
Thank you for reply.
By the way, how do you make the integral sign so large? Latex? I had tried to type in the Latex code but it didn't work.
This seems a better path, I'll try, thank you.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
