Calculate the angular momentum of this particle in rotational motion
The discussion focuses on calculating the angular momentum of a particle in rotational motion, emphasizing the need to use the vector cross product rather than regular multiplication. The correct formula for angular momentum is given as L = p × r, highlighting the importance of understanding vector operations. A participant points out that the initial multiplication presented is not a proper cross product, which only exists in three dimensions. The conversation also touches on the anti-symmetry property of the cross product and clarifies misconceptions about two-dimensional vector multiplication. Overall, the thread underscores the significance of correctly applying vector mathematics in physics.
YanZhen
The mass of the particle is m,the equation of motion is r=acosωti+bsinωtj.a and b are constant.Calculate the angular momentum of a particle at any time.
L=P*r=m*v*r
v=dr/dt
i,j,k arevector
I know L=P*r=m*v*r=m(acosωti+bsinωtj)*(-aωsinωti+bωcosωtj)=mabw((cos^2)ωt+(sin^2)ωt)k=mabωk.
but why m(acosωti+bsinωtj)*(-aωsinωti+bωcosωtj)=mabw((cos^2)ωt+(sin^2)ωt)k.I need some detail.
please help me.
You should not be using regular multiplication to multiply vectors, you need to use the vector valued cross product to define the angular momentum:
\vec L = \vec p \times \vec r
where
\hat i \times \hat j = \hat k, \quad \hat j \times \hat k = \hat i, \quad \hat k \times \hat i = \hat j
and furthermore you have anti-symmetry so ##\vec u \times \vec v = - \vec v \times \vec u## for any vectors ##\vec u## and ##\vec v##.
IIRC $$\vec L\equiv \vec r \times\vec p$$ :wink:
Too busy arguing about the need to use the cross product to care about getting the right definition I suppose ... 🤷‍♂️
  • Haha
Likes berkeman and BvU
where
wow,thanks for your wonderful answer,it solved my question.and it also requires a point of knowlege about vectors.(x1,y1)X(x2,y2)=x1y2-y1x2
Careful. This is not the cross product. It is a component (the third) of the cross product between two vectors that only have i and j components. The cross product as such does not exist in two dimensions (although there are generalisations of it that do - among them the wedge product, which would look something like what you wrote but is generally too advanced for basic introduction to vectors and their application). The general form of the cross product (in three dimensions) would read
(x_1,y_1,z_1) \times (x_2, y_2, z_2) = (y_1 z_2 - y_2 z_1, z_1 x_2 - z_2 x_1, x_1 y_2 - x_2 y_1)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
