Calculate the Average Surface Temperature of Earth
In summary, the Earth receives 390 W/m2 of radiant thermal energy from the Sun and radiates an equal amount back into space, maintaining a thermal equilibrium. Assuming the Earth is a perfect emitter (e = 1), the estimated average surface temperature of the Earth is 288 Kelvin or 15°C. This can be calculated using the equation P = eσAT^4, where P is power, e is emissivity, σ is the Stefan-Boltzmann constant, A is surface area, and T is temperature. However, considering the Earth's albedo of 30%, the temperature is actually lower at 255K.
lasisdabomb
The Earth receives on average about 390 W m−2 of radiant thermal energy from the Sun, averaged over the whole of the Earth. It radiates an equal amount back into space, maintaining a thermal equilibrium that keeps the average temperature on Earth the same. Assuming the Earth is a perfect emitter of radiant energy (e = 1), estimate the average surface temperature of the Earth in °C
P = eσAT^4
P ∝ T^4
λmaxT = 2.898 × 10−3 m K
3. Attempt
I've tried all these formulas, but I'm not getting anywhere. Am I supposed to know the surface area of the Earth because I feel like it's impossible without it
Assume the area of the Earth to be ##A##, a variable. What, then, is the total power incident on the Earth's surface?
Is the 390 m^-2 relevant for the equation. Should that be stated as the P value or should it just be 390W
Do you know what intensity is? It's formula? It's unit?
I've realized how to do it. The Power is average for each m^2 of earth. That means the surface area should be 1m^2 and the Power should be 390.
By subbing everything in, you get an average surface temperature of 288 Kelvin or 15°C
More appropriate wording would be - an average of 390W of power is incident per sq.m on the surface of the earth. This is what you mean, right?
And congratulations, on having solved the problem:smile:
Yes, that's the right answer with the given information, but 390 W/m2 is too high. Should be more like 340.
Taking the 30% albedo into account as well would bring the temperature down to 255K, which is the standard result.
Likes Qwertywerty
Thanks for the info!
Related to Calculate the Average Surface Temperature of Earth
1. What is the average surface temperature of Earth?
The average surface temperature of Earth is approximately 15°C (59°F). This is the average temperature across all land and ocean areas on Earth.
2. How is the average surface temperature of Earth calculated?
The average surface temperature of Earth is calculated by collecting temperature data from various locations across the globe and averaging them together. This includes data from land-based weather stations, ocean buoys, and satellite measurements.
3. Has the average surface temperature of Earth changed over time?
Yes, the average surface temperature of Earth has changed over time. The Earth's surface temperature has been increasing at an alarming rate since the Industrial Revolution, primarily due to human activities such as burning fossil fuels and deforestation.
4. What is the significance of the average surface temperature of Earth?
The average surface temperature of Earth is a key indicator of the health of our planet. It affects weather patterns, sea levels, and the survival of various species. It is also an important factor in understanding climate change and its potential impacts on our planet.
5. Is the average surface temperature of Earth the same everywhere on the planet?
No, the average surface temperature of Earth varies depending on location. Generally, temperatures are higher near the equator and lower towards the poles. Other factors such as elevation, land cover, and ocean currents also play a role in regional temperature variations.
  • Thermodynamics
13K
