Calculate the current i3 in the following configuration
The discussion focuses on calculating the current i3 in a circuit with two batteries and resistors. The provided values include EMF_1 at 6 V, EMF_2 at 3 V, R_1 at 70 Ohm, and R_3 at 20 Ohm. The user initially struggles with applying the formula V=IR due to the presence of two batteries. However, they later indicate that they have resolved the issue and found the solution. The conversation highlights the challenges of circuit analysis involving multiple power sources.
shimizua
Calculate the current i3 in the following configuration:
http://capa-new.colorado.edu/msuphysicslib/Graphics/Gtype57/prob06_kirch.gif
EMF_1 = 6 V
EMF_2 = 3 V
R_1 = 70 Ohm
R_3 = 20 Ohm
I know that V=IR so I=V/R
but because there are 2 batteries i am just having a little bit of a problem.
tried adding up the batteries but it does not seem to be working
nm, i figured it out
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
