Motional emf will be induced in the rotor. Use E=BLVsinθ*N (where v=rw and N=number of turns of rotor).bassi ali said:hi,
How can I demonstrate the relationship of the electromotive force of a motor AC
thank you
For detailed demo, you can first prove the motional emf equation using Lorentz's force(F=BILsinθ) applied on electrons of a conductor and then apply the emf equation to this alternator.bassi ali said:hi,
thank you
Then you should use Faraday's laws.bassi ali said:the rectangle is fixed and the flow varies,
Right.bassi ali said:I think to use Faraday's relationship e = - dΦ / dt (the derivative currency flows on derivative temp).
in using Φ=∫∫ B.dS
Then you should assume the varying flux as a cosine wave.bassi ali said:but i find this expression : E = N L r w B cos(wt)
====> must find sin (wt) instead of cos (wt)
Your varying flux function should be predefined, either sin or cos. If it is sin, emf will be in cos(wt).bassi ali said:i have cos(wt) not sin(wt) !
The formula for calculating electromotive force E is E = I(R + r), where E is the electromotive force, I is the current, R is the internal resistance of the source, and r is the external resistance.
The electromotive force E is measured in volts (V) using a voltmeter.
Yes, the electromotive force E can be negative if the direction of the current flow is opposite to the direction of the voltage.
The value of electromotive force E is affected by the strength of the magnetic field, the number of turns in the coil, and the speed of the relative motion between the coil and the magnetic field.
Electromotive force E is used in various real-life applications such as electric generators, batteries, and power supplies. It is also used to measure the strength of electric currents and as a driving force for electrical devices.
