Calculate the energy consumption from a double fitting light
The discussion centers on calculating energy consumption for a room with 12 double fitting fluorescent lights rated at 85W. Participants debate whether the 85W rating applies to each bulb or both collectively, with a consensus leaning towards the assumption that each fixture contains two 85W lamps. The term "double fitting" is questioned, with suggestions that "twin fitting" or "twin bulb" may be more accurate terminology. Clarifications on standard fluorescent fixtures indicate that they typically hold two tubes, which could be either 85W or smaller options. Overall, the focus remains on accurately determining the energy consumption based on the lighting specifications provided.
t0mm02
nothing
No equations
Hello everyone. I have a question that as simple as it looks it is making me doubt if I answered the correct solution.
A room is illuminated by 12 double fitting 85W fluorescent lights and I got to calculate the energy consumption.
I multiplied 12 x 2 because it says it is double fitting but I actually don't know if the 85W is for both of them or for each (it does not say anything specifying)
I would think that you are right to assume that each fixture has two 85W lamps, since the other option would be two 42.5W lamps to make the 85W, and there is no standard bulb that I know of that is 42.5W. Still, I've never heard the term "double fitting" in the context of lamps. Is that the question in English, or translated from another language?
My guess is that these are standard fluorescent fixtures, which typically hold two tubes. Some smaller (1" diameter, 48" length) tubes I have are 32 W. each. Longer and fatter tubes could be 85 W. apiece.
Yeah, doing more searching, "twin fitting" or "twin bulb" light fixture seem to be more common terms.
I assume this is for lighting in a museum dedicated to the topic.
