MHB Calculate the radius of the circle
  • Thread starter Thread starter Help seeker
    Circle Radius
To calculate the radius of the circle with points A, B, and C, the angle ABC is 75 degrees, leading to an arc AC and angle AOC of 150 degrees. The area of sector AOC is determined to be (5πr²)/12, while the area of triangle AOC is calculated using the formula (1/2)hb, resulting in r²sin(75)cos(75). The area of the shaded segment is derived from the difference between the sector and triangle areas, equating to 200 cm². The final equation for the radius r is established as (5π/12 - sin(75)cos(75))r² = 200.
Help seeker
A, B and C are points on a circle with center O. Angle ABC = $75°$ . The area of the shaded segment is $200cm^2$ .
Calculate the radius of the circle. Answer correct to $3$ significant figures.
Mathematics news on Phys.org
What is the angle AOC? In terms of $r$ (the radius of the circle), what is the area of the triangle AOC? What is the area of the sector AOC of the circle? The difference between those last two areas is the area of the shaded segment. That should give you an equation for $r$.
An angle with vertex on a circle cuts that circle in an arc with measure twice the measure of the angle. And an angle with vertex at the center of the circle cuts that circle in an arc with measure equal to the angle. Here angle ABC has measure 75 degrees so arc AC and angle AOC have measure 150 degrees. Knowing that, you can find the areas of segment AOC and triangle AOC as functions of r, the radius of the circle, Subtract those to areas to find the area of the gray region as a function if r, set that equal to 200, and solve for r.
Since this has been here a while:
Sector AOC is 150/360= 15/36= 5/12 of the entire circle, The entire circle has area $\pi r^2$ so sector AOC is $5\pi r^2/12$. Triangle AOC is an isosceles triangle with two sides of length r and vertex angle 150 degrees. An altitude of triangle AOC bisects angle AOC so divides triangle AOC into two right angles with hypotenuse of length r and one angle 150/= 75 degrees. The "near side", the altitude, has length h= r cos(75) and the "opposite side", half of AC, has length b= r sin(75). All of AC, the base of triangle AOC, has length 2r sin(75) so triangle (1/2)hb= r^2 sin(75)cos(75).
So the shaded segment has area $\frac{5\pi r^2}{12}- r^2sin(75)cos(7)= \left(\frac{5\pi r^2}{12}- sin(75)cos(75)\right)r^2$.
Tnx.
SOLVED
Brandy induced ramblings follow.
Country Boy said:
So the shaded segment has area $$\frac{5\pi r^2}{12}- r^2sin(75)cos(7)= \left(\frac{5\pi r^2}{12}- sin(75)cos(75)\right)r^2$$
Minor typo.
That should have been
$$\frac{5\pi r^2}{12}- r^2sin(75)cos(75)= \left(\frac{5\pi}{12}- sin(75)cos(75)\right)r^2$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
