Calculate Work done in square form?
Work can be calculated in square form similarly to rectangular form by using the area of a square to represent work done. If the force and displacement are equal in length on a graph, the area of the resulting square (Force times Displacement) accurately reflects the work done. Rescaling one or both axes on a graph allows for the conversion of a rectangle into a square without altering the work calculation. Therefore, it is indeed possible to calculate work done in square form. The graphical representation remains valid regardless of the shape used.
arslion
can we calculate work done in square form ??as we calculate it in rectangular form.Work done by graphical method is an example..
In rectangular form
Area = OA x OC = xy = FS
W=A
but when we calculate it in square form the area of square is x2.
is it possible ??
check attached image for help
Thanks
http://arslion.blogspot.com"
To quote a famous person, "Yes, we can." If on your Force versus Displacement graph the size of the force is the same length (in centimeters) as the Displacement, then you get a square and the work done by the force is represented as the area of the square, Force times Displacement.
Stated differently, if you have a rectangle, you can always rescale one or the other (or both) of the axes to get a square. This will not in any way change the work done by the force.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
