Calculatin coefficient of friction for a scooter
The discussion focuses on designing a lab experiment to determine the coefficient of friction for a razor scooter by varying velocities and distances. It is suggested that instead of proving the coefficient remains constant, the experiment should focus on measuring distance and time to calculate velocities. The conservation of energy equation is emphasized, allowing for simplification that eliminates mass from the calculations. For graphing, it is recommended to plot distance against time to derive the necessary relationships. Overall, the conversation highlights the importance of clear experimental design and appropriate data representation.
besaw212
My task is to design a lab in which i can solve for the coefficient of friction for a razor scooter( the little medal kids one). I planned on varying velocities and distance to show that the coefficient remained constant. Does anyone see any improvements that could me made or variables that i should take into account? Thanks alot!
I was going to use KE1= W2
.5mv^2=FN X u X d
If you are going to solve for it, I do not believe it makes sense to show that it remains constant. The only reason I could see for having to show that it is constant is if you keep changing the surface (meaning that you are testing the surface properties and not really the scooter and one surface if you get what I am trying to say).
I suggest that you just go along measuring the distance and time to get the velocities and apply conservation of energy as you have in your relevant equations. If you simplify this equation you can just measure 't' and 'd' and plot an appropriate graph to get the coefficient of friction μ.
Thanks i see what your saying. Just one question about the graph. I'm having trouble deciding what should be on each axis. Would it be a KE vs D or would a mass drop out on each side and you would be left with velocity vs D ?
Well I think if you measure 'd' and 't' since acceleration will be constant, v=d/t which you can put into 0.5mv2= μFnd and get 'd' in terms of 't'. The mass will cancel out so your equation should not involve 'm' at all.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
