Calculating Acceleration and Force in an Electromagnetic Rail Gun
An electromagnetic rail gun uses a magnetic field and electric current to propel a projectile, with a setup involving two parallel rails and a conducting rod. The rod experiences a force due to the current and magnetic field, calculated using the equation F = I L x B. The initial calculation for acceleration was incorrectly noted in units, but the correct acceleration is determined to be 0.8625 m/s². After traveling 8.00 m, the rod's speed is calculated to be 6.9 m/s², and the force acting on the rod is directed north. Understanding the cross products in the force calculation is essential for accurate results.
kavamo
An electromagnetic rail gun can fire a projectile using a magnetic field and an electric current. Consider two parallel conducting rails, separated by 0.575 m, which run north and south. A 49.0-g conducting rod is placed across the tracks and a battery is connected between the tracks, with its positive terminal connected to the east track. A magnetic field of magnitude 0.750 T is directed perpendicular to the plane of the rails and rod. A current of 2.00 A passes through the rod.
If there is no friction between the rails and the rod, how fast is the rod moving after it has traveled 8.00 m down the rails? What direction is the force on the rod?
F = qVxB (where V and B are vectors)
F = I LxB
a = ILB / m
a= (2.0 A)(0.575m)(0.750T)
a = 0.8625 m/s
I've drawn the picture and can determine (see) that the force in in the North direction. So I just need help figuring out the acceleration. I think there must be some cross products but don't really understand how to do that.
Thanks in advance for your help.
Didn't you already calculate the acceleration? The unit should be m/s^2, not m/s.
Sorry, I got confused.
So then to answer the actual question I multiply 0.8625 by 8.0 meters
(0.8625)(8.0) = 6.9 m/s^2
Thanks.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
