Calculating Air Pressure: Ideal Gas Law Homework Solution
The discussion centers on calculating air pressure using the Ideal Gas Law based on provided data. The user successfully calculated the cylinder pressure as 768 mm Hg and determined the moles of air to be 1.448×10^-4 mol. However, confusion arises regarding the calculation of air pressure at high temperature, with differing results from classmates. The user questions whether to use the volume from the previous calculation for this step, indicating uncertainty about the experimental setup. Clarification on the variable "h" and the cylinder's characteristics is also sought to better understand the calculations.
aaronfue
I'm trying to calculate the air pressure from some data that I have.
#1. Calculate the cylinder pressure. (barometric pressure=765 mmHg, h=35mm)
#2. Calculate the moles of air using low temperature and volume and cylinder pressure above. (Low temp=50.0deg Celsius, vol=4.0mL, R=62.36)
#3. Calculate the air pressure using the high temperature reading from data. (High temp = 80deg Celsius)
Ideal Gas Law
PV=nRT
I have converted the temps to Kelvin and the mL to L. I have also made a -0.2 mL correction to my volume.
Question #1= 768 mm Hg
Question #2 = 1.448×10-4 mol air
Question #3 = The question doesn't say to use the volume for that high temp, so I use it anyways. Another classmate got 420 mm Hg. But I don't get that. I get 480+ mm Hg.
Should I use the volume from question #2 since #3 doesn't specify?
The data that was collected is the same as my classmates but I don't know where I am making my mistake!
I would appreciate any assistance with this!
Cylinder? h? You have to explain what you are talking about.
I'm eventually going to find the enthalpy of vaporization of water. The pressure of the cylinder is what needs to be determined which is asked in the first question.
The value of h is given in the first question in parenthesis. I was able to calculate the cylinder pressure. I just needed help with my moles of air from the second question.
You have still not explained what the h is. I can do some guessing, but that would be a waste of time, as I don't know what is the setup, if the cylinder is rigid, or closed with a piston, why the pressure inside is different from atmospheric and so on. Basically I know nothing.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
