MHB Calculating Amount of Pure Acid Needed for Desired Solution
  • Thread starter Thread starter mathdad
    Acid Pure
To create a 30% acid solution from a 10% solution, the chemist needs to determine the amount of pure acid to mix with 5 milliliters of the 10% solution. The correct equation is 0.30(x + 5) = 0.10(5) + x, where x represents the volume of pure acid in milliliters. This equation balances the concentration of acid in the final solution. The discussion highlights the challenge of translating word problems into mathematical equations, emphasizing its importance in practical applications. Mastering this skill is crucial for success in various fields, including finance.
mathdad
A chemist needs a 30% acid solution. How much pure acid needs to be mixed with 5 milliliter a of a 10% acid solution to obtain the desired solution?
The words PURE ACID for some reason or another point to 100 percent.
My equation:
0.30(x) + 0.10(5) = (x + 5)
Is this right?
Mathematics news on Phys.org
What you want, where x is the amount of pure acid added in mL:
0.10(5) + x = 0.50(x + 5)
One of my greatest struggles in math is to create an equation(s) from the words in applications. It is clearly the most important, in my opinion, math skill to learn. I vividly recall getting rejected for a Financial Advisor job in 2006 because I simply could not pass the bank test, which consisted mostly of word problems. The F. A. job could have changed my finances for the better. I took this test (and other exams) after earning my B.A. degree in 1994.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
