Calculating Apparent Depth of Print Beneath Flint Glass Plate
The discussion revolves around calculating the apparent depth of print beneath a 3.5 cm thick flint glass plate, using the refractive index of flint glass, which is 1.66. The initial calculation suggests that the apparent depth is 2.1 cm, derived from the formula apparent depth = actual depth / refractive index. Participants emphasize the importance of confidence in optics solutions and recommend drawing a ray diagram to visualize the refraction process. They discuss Snell's law, noting that angles in air can be approximated as small, aiding in understanding the light's behavior at the glass-air interface. The conversation concludes with a reinforcement of the explanation provided.
Aoiumi
A flint glass plate 3.5 cm thick is placed over a newspaper. How far beneath the top surface of the plate would the print appear to be if you were looking almost vertically downward through the plate?
N=1.66 for flint glass
Apparent = d/n
Apparent depth = 3.5 cm /1.66
= 2.1 cm
I'm not sure if this answer or the formula I used are correct. Thank you.
You're right.
You can have more confidence in your solutions, especially in optics, if you draw the ray diagram (using Snell)
One ray travels straight up through the glass "n" into air, undeflected at the surface (sin theta=0).
The other ray goes thru the glass at angle theta_glass from the normal, but deflects as it leaves the glass,
to angle theta_air ... if these angles are small, sin theta ≈ theta.
Using Snell, that means the angle in air is ≈ theta_glass / n.
Likes 1 person
Thank you for your explanation!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
