MHB Calculating Average Acceleration for Changing Velocity and Direction
The discussion focuses on calculating the average acceleration of a car that first moves north at 50 mph and then turns 45 degrees east at 55 mph. The initial and final velocities are analyzed in both x and y components, with the average acceleration calculated as a change in velocity over time. The initial calculations yielded average accelerations of 389 mph/h for the x component and -161 mph/h for the y component, but adjustments were made after realizing the correct initial velocity for the y component should be 50 mph. Ultimately, the corrected average acceleration is approximately (388.9, 111.1) mph/h, confirming the method's validity.
ognik
I would just appreciate someone checking this please, I'm not sure of my answer ...
Q: Car moves North with constant speed 50 mph for 5 mins. It then turns 45 degree east and continues at 55 mph for 1 min. Find ave. acceleration.
For x, y components, Cos45 = Sin45 = 0.7, so for the 2nd part $v_x = v_y = 55 \times 0.7 = 38.9 $ mph for 1 min
So, $ a_x (ave) = \frac{\Delta v_x}{\Delta t} = \frac{38.9 - 0}{5 + 1}(60) = 389 $ and $ a_y (ave) = \frac{\Delta v_y}{\Delta t} = \frac{38.9 - 55}{5 + 1}(60) = -161 $ ?
Mathematics news on Phys.org
What units do you think your average acceleration has?
Hi - was not really worrying about getting the units strictly correct, just wanted to make sure I understood how to apply the average in this situation (where to me the average acceleration seems a bit meaningless)... but the units should be mph ph or $\frac{miles}{hour^2}$
Average acceleration is change in velocity divided by the time. Here the initial velocity is $v_0=(0,50)$ and the final velocity is $v_1=(38.89,38.89)$ in units of mph, and the time interval is $6$ minutes or $1/10$ hours.
So the average acceleration is:
\overline{a}=\frac{(38.89,38.89)-(0,50)}{1/10}=10(38.89,-11.11)=(388.9,111.1) \mbox{ mph/h}
So my method seems ok thanks (I noticed I used 55 instead of 50 for the y component).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
