Calculating Balloon Range and Altitude
The discussion revolves around calculating the range and altitude of a hypothetical vacuum airship using given parameters such as displaced volume, mass, and net force. The user acknowledges the need to factor in changes in pressure and density with altitude, as the maximum altitude is reached when buoyant force equals weight. There's also a mention of the limitations of conventional materials like latex in weather balloons, which expand until they burst. The user reflects on their thought process and recognizes the importance of understanding buoyancy dynamics in their calculations. Ultimately, the conversation highlights the complexities involved in determining the behavior of buoyant objects in varying atmospheric conditions.
KJ4EPE
I feel kinda stupid asking this, since I have a bachelor's degree in physics. But, here it goes: I'm doing a thought experiment on my own (i.e., not a homework problem) for a hypothetical vacuum airship. I've determined the following quantities:
V_displaced = 15 m^3
m = 13.5 kg
F_net = F_buoyancy - Weight = 44.0 N upwards
a = 3.26 m/s^2 upwards
I'm assuming that winds are calm (i.e. v_wind = 0), and I've not factored in how pressure and density change over altitude.
Again, I feel like a dunderhead for asking this, but using these quantities, how can I calculate range and altitude? All the equations I know involve the use of initial velocity, but the only forces acting on the airship are gravity and the buoyant force.
Okay, I thought about it some more, and I realized: I will need to factor in the change of pressure and density, because the maximum altitude is when the buoyant force is equal to the weight. Duh. Now I'm off to figure that out.
Are you still working on this? Remember that for a conventional "weather balloon", the material is latex which will allow the lifting gas to expand and expand until the balloon bursts. If you have a determined enevelope which won't expand over a predetermined volume, that's going to be your max altitude...I think...
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
