Calculating Car Acceleration on a 1.2 Meter Hill in 2 Seconds
  • Thread starter Thread starter steve986
    Homework
To calculate the acceleration of a car traveling down a 1.2-meter hill in 2 seconds, use the equation d = (1/2)(a)(t)^2, where d is the distance, a is acceleration, and t is time. Since the initial velocity (vi) is zero, the equation simplifies to d = (1/2)(a)(t)^2. Rearranging this gives a = (2d) / (t^2). By substituting the values, you can find the acceleration without needing additional variables. This method effectively bypasses the need for force calculations.
steve986
calculate the acceleration of a car that travels down a hillthat is 1.2 meters long in 2 seconds
a=f/m
all that i have down is the forula but there is no other variables.
--im stumped
Use the constant acceleration motion equations. If you don't know them google motion equations
wow they are really confusing
is there a way i can get the solution without trying to figure them out?
how can i find the force if i don't even know the acceleration?
imm really pissed at my science teacher right now
wait... i have this nifty little equation you can use to calculate the acceleration with the final velocity... d=(vi)(t)+(1/2)(a)(t)^2 vi is the initial velocity, and that equals zero, so you can cut that out and use the d=(1/2)(a)(t)^2 and work the equation to equal a... that is all i am going to give you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
