Calculating Charge on a 1.72 g Gold Nugget
  • Thread starter Thread starter Purduenub03
    Charge Gold
To calculate the net charge of a 1.72 g gold nugget after removing 1% of its electrons, first determine the total number of electrons in the nugget, which is approximately 4.154 x 10^23. Removing 1% of these electrons results in about 4.154 x 10^21 electrons being removed. Each electron has a charge of -1.602 x 10^-19 C, so the total charge removed is approximately -6.65 x 10^2 C. The nugget's net charge becomes positive due to the loss of negatively charged electrons, resulting in a net positive charge. The calculation confirms the importance of accurately determining the number of electrons and applying the charge of an electron to find the net charge.
Purduenub03
I'm sure I am missing something simple here but...
Suppose a 1.72 g nugget of pure gold has zero net charge. What would be its net charge after it has 1% of its electrons removed?
So i know that an electron is 9.109 x 10^-31 kg, and has a charge of -1.602 x 10^-19C. However, how do i know the split of electrons and protons in the gold bar?
I'd assume I am trying to get to mass of electrons / mass of electron, that times the charge of an electron divided by 100?
How many electrons in a Gold atom ? How many atoms in 1.72 g ?
79 electrons in a gold atom
1.72/196.96654 = .008732 atoms
so .008732 * .79 * 1.602 x 10 ^-19 ?
Okay,you're on the wrong track...
197g gold----------------------------->6.023 10^{23} atoms
1.72g gold----------------------------> x atoms
1 atom gold---------------------------> 79 electrons
x atoms gold---------------------------> y electrons
What do you get for "y"??
Daniel.
(1.71 / 197) * 6.023 X 10 ^23 * 79 = 4.154 x 10 ^ 23
AH!
and that divided by 100 x the charge is the answer
thank you
Ryan
Not so fast !
You've only found the number of electrons removed. Multiply this number by the charge on an electron to get the net positive charge.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
