Calculating Charge on Second Capacitor Connected to Battery
  • Thread starter Thread starter santina91
    Capacitors Charge
A capacitor with a capacitance of 10 F charges to 100 C, indicating a battery voltage of 10 V. After discharging, a second capacitor of 20 F is connected in parallel. The charge on the second capacitor can be calculated using the formula Q = CV, where V is the constant voltage of the battery. Since C2 is double C1, the charge on the second capacitor will be 200 C when connected to the battery. The problem emphasizes understanding the relationship between capacitance, voltage, and charge.
santina91
A capacitor of C1 = 10 F is connected to a battery, and a charge of 100 C builds up on the capacitor. Then, the battery is disconnected, the capacitor is discharged, and a second capacitor of capacity C2 = 20 F is connected to it in parallel. Then, the two capacitors are connected to the same battery. What is the charge on the plates (in C) of the second capacitor at that time?
Q=CV
C1+C2=C
t=RC
q=Q0e^(-t/T)
So far the only thing I have come up with to do is find the voltage of the battery by doing 100=10V. That would mean the battery is 10V, but I do not know if this is right or what to do next.
note: it is all microcolumbs and microfarrhads
First of all - please. farads after Michael Faraday.
Second of all here's a μ to help you.
As to the capacitors I think all they want is for you to figure the battery voltage and then figure the charge on the second capacitor.
This problem is much easier than you're making it.
You have the formula Q = CV. You don't know what V is but you know it is constant.
C2 is twice as large as C1.
What happens to Q in the equation if you double the value of C and keep V constant?
just remember that U=CV
from the givens you found that teh voltage of the battery was 10V
now all you have to do is use that voltage in the equation to find the energy of the second capacitor.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
