Calculating Collision Time: Astronaut's Experiment on Alien Planet
An astronaut conducts an experiment on an alien planet by launching a ball upward while simultaneously dropping another ball. The key to solving the collision time lies in using kinematic equations while carefully considering the initial conditions and direction of acceleration due to gravity. The equations for both balls must reflect their respective positions and velocities, with attention to the signs for upward and downward motion. The discussion emphasizes the importance of consistent setup in the equations to accurately determine the time of collision. Properly applying these principles will yield the correct time for the two balls to collide.
Malgrif
An Astronaugt is doing an experiment on an alien planet. She fires a ball straight up towards a target ball that is dropped at the same time as the lower ball is launched. If air resistence is ignored, how long does it take for the two balls to collide?
Kinematics equations.
So we know that the two balls have three things in common. Time of collision, acceleration, and the displacement that they'll collide.
d1=.5at^2 and d1=.5at^2 + v1t (for the ball being launched)
I subed the two equations into each other and it didn't really work out... I'm thinking it has something to do with the signs or are my equations wrong all together? Thanks for the help.
Your equations are ok, but you need to be careful in setting them up.
If y is positive then v is (+) and g is (-).
Where they collide is going to be y for both as you note and t is the same, so apparently you should end in an answer that depends on initial velocity and the original distance to the target.
So ...
y = v*t - 1/2*g*t2
and
y = d - 1/2*g*t2
Is there a numerical answer to this question? I used your equations and ended up with t = d/v.
and just to clarify, does your equation mean mean the total distance from the freefalling ball to the ground minus how much the ball free fell before the second ball collided with it?
No.
Yes.
When you set up the equations be careful to consistently express the initial conditions. In the case of the second equation, the target was dropping from height d. So the initial condition for the target, must include its distance above the planet at the start. The height of the one from the surface was 0 of course.
The complete equation applied to both is of the form ...
y = yo + v*t + 1/2*g*t2
... but you need to adjust the signs to reflect which direction is positive y.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
