Calculating current in five resistor/two battery circuit
To calculate the current in a circuit with five resistors and two batteries, the node law and loop law are essential. The correct relationship for the currents is I2 = I1 + I3, with I1 equating to I4 and I2 to I5. The discussion emphasizes the importance of defining current directions at nodes to avoid sign errors and suggests using three equations for three unknowns. By applying Kirchhoff's Current Law (KCL) correctly, one can simplify the problem significantly. Following these guidelines will lead to a clearer solution for the circuit's current distribution.
ddobre
The circuit above has five resistors. Calculate the current through each.
I1 = I2 + I3 (Node Law)
∑Vi = 0 (Loop Law)
I tried to equate the currents using the node law, with I3 = I1+I2+I4+I5
But I see a flaw here, because the currents seem to oppose each other at the node. Anyway, I tried to solve a system of equations using the above relation of currents, and seemed to get nowhere. Any advice?
The correct equation is ## I_2=I_1+I_3 ##. Do you see why? With that correction, it should work. Also ## I_1=I_4 ##, and ## I_2=I_5 ##. You only need 3 currents.
Is it because I1 and I3 meet at the node at the top, which then turns into I2? Almost forgot series resistors have equal current, that simplifies a lot.
Likes Charles Link
Note: You are basically solving a system of 3 equations and 3 unknowns (## I_1, I_2, ## and ## I_3 ##). Since you already have one equation, ## I_2=I_1+I_3 ##, you only need 2 voltage-loop equations. (The 3rd voltage loop equation would simply follow from the other two).
Likes ddobre
In my opinion you should always apply KCL like this...
1) Define currents going into (or out of) a node as positive and write down your decision!
2) Then apply KCL and sum the currents to zero.
So with reference to the top node in your diagram...
1) I define into a node as +ve. So therefore...
I1 and I3 are +ve
I2 is -ve
2) The sum is...
(+I1) + (-I2) + (+I3) = 0
Obvious some symbols and brackets are unnecessary but I have included them to make the point about you "summing to zero". If you do it this way you are much less likely to make a sign error. You can now rearrange it how you like, for example my equation becomes...
I1 + I3 -I2 = 0
or
I1 + I3 = I2
Likes Charles Link
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
