Calculating distance between lux meter and light source
Calculating the distance between a light source and a lux meter can be approached using the inverse square law (ISL), which states that lux equals luminous flux divided by the square of the distance. However, the effectiveness of ISL may vary based on the light source's characteristics, such as its area or if it is a laser, which can complicate the measurement. Experimental data is essential to determine the distance at which ISL accurately applies. It is recommended to conduct experiments to identify the threshold distance for reliable results. Understanding these factors is crucial for accurate distance calculations in lighting experiments.
san-yas
I am currently performing some experiments to calculate the distance between a light source and a lux meter where the light source points directly towards the lux meter.
Is it possible to calculate the exact distance between the light source and the lux meter given that we have a lux value (through the lux meter) and the luminosity flux (through the information given by the light source manufacturer)? or is the inverse square law (lux=lm/d^2) subjected to particular conditions?
Science news on Phys.org
Welcome to PF.
It seems like the inverse square law should work for this. What have you seen in your experimental data so far?
san-yas said:
a light source
If the source has a significant area then ISL will stop working close up. Also, if the source is a laser, you will have a problem because the effective position of the source can be may metres behind the front (multiple mirror images, as with an infinity mirror) and the r in 1/r2 would need to be corrected for. ISL is fine for stars and planets but the Moon and Sun are very much distributed sources.
I would be inclined to do the experiment first and find what distance the ISL begins to work for.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
